Thread: Replacement DMF Failing after 15K Miles?
  1. Replacement DMF Failing after 15K Miles?
    Apr 2009
    I posted previously about having the DMF replaced at 28K on my 2006, 1.9 TDI and got some very helpful advice.
    The car doesn’t get heavy usage and since then, I’ve only clocked up just over 15K miles and am starting to experience all the same symptoms again!
    Before getting onto my local dealer, I was wondering has anyone else experienced multiple DMF failures at such low mileage and is there anything else obvious that would cause lumpy tick over at idle, rough start etc.
    Worst case scenario, if I am looking at another DMF replacement do you think there is any chance VW would cover some/all of the cost?
    I never thought I’d be contemplating replacing the flywheel in any car more regularly than it needs a service!
  2. Re: Replacement DMF Failing after 15K Miles?
    Norfolk
    "lumpy tick over at idle, rough start etc."
    Doesn't sound like a dmf fault. A DMF fault will usually be felt through the clutch and heard as a clatter.
  1. How economical is your Golf?
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 21-07-2011, 09:05 AM
  2. Question Clutch fail after Cambelt replacement and MOT at Audi garage
    By clivethegadget in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-05-2010, 08:46 PM
  3. miles per gallon
    By tlionhart in forum Chat - Anything with wheels
    Last Post: 11-06-2009, 07:22 PM
  4. A6 Avant 03 plate 2.5tdi gearbox
    By johnm in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2009, 06:50 PM
  5. Mk 3 Diesel Cam belt change
    By johnnie in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-10-2006, 12:03 PM
