Thread: Reset central locking on '02 passat
  1. Reset central locking on '02 passat
    Nov 2006
    My car was in at the Body Shop last week and they said the battery had went flat whilst it was in their care.
    Since getting the car back, neither of my key fobs will open 'all the doors' with 2 presses of the unlock button. Only the drivers door unlocks with the fob.
    It's strange because all the doors unlock manually with two turns of the key in the door lock and also with the button inside the drivers door next to the electric window buttons.
    The owners manual gives a reset procedure, but only for when the fobs don't open any doors. I have tried this to no avail.
    Please can anyone shed any light on this as it is rather annoying.
    I'm inclined to think it is something to do with the battery going flat, although I have had the battery go flat when I've left the car for a few weeks, then charged it up, without any problem.
  2. Re: Reset central locking on '02 passat
    Jun 2006
    UK, Mids
    It is a common problem. t usually clears after 2 weeks oor so, or you can just disconnect and reconnect the battery. The CCM gets scrambled at low voltage and needs a 'cold reboot' equivalent.
    Audi A8 - 2015 - 3.0TDI
  3. Re: Reset central locking on '02 passat
    Norfolk
    If it doesn't reset you will have to get it recoded. Sometimes a code changes as a result of a flat battery or more likely a power surge. Anyone with vag-com/VCDS can do it.
  4. Re: Reset central locking on '02 passat
    Nov 2008
    I'dbeen having this driver's door only issue for a few months and it was a pain having to use the internal unlock button to get the other doors open.
    I'm pleased to report that disconnecting the battery for a short while did the trick.
    Excellent advice - Thank you!
  1. Please Help Octavia- Central locking keeps locking.
    By Mawb in forum Octavia
    Last Post: 27-09-2013, 02:53 PM
  2. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  3. caravelle central locking problem
    By buxtonguy in forum Touran - Sharan - Caravelle
    Last Post: 18-05-2010, 05:38 PM
  4. Central locking on 52 reg passat
    By pkny in forum New Member Introductions
    Last Post: 04-08-2009, 01:10 PM
  5. PASSAT REAR CENTRAL LOCKING
    By Tractor Dave in forum Chat - Completely Off Topic
    Last Post: 12-01-2007, 01:46 PM
