Thread: diesel filter on 170 tdi
Results 11 to 20 of 31
  1. #11
    May 2007
    knee deep in clunge
    14 Post(s)
    Sent from my iPhone using
    My fat fingers
  2. Re: diesel filter on 170 tdi
    DSG4ME Guest
    Be careful with the alloy pipes on the filter lid, try not to stress them, they are a weak point and a new filter house is £180.
  3. Re: diesel filter on 170 tdi
    Sep 2008
    hi all
    just got round to taking a sample from the filter housing and it don't look to good, i have put an atttachment with this post so you can see what i mean, hopefully the attachment has worked, all opinions are welcome
    thanks again
    colin
  4. Re: diesel filter on 170 tdi
    1837 Post(s)
    That must have some engine oil in the tank.
  5. Re: diesel filter on 170 tdi
    Sep 2008
    any ideas how that could happen, i know i've not put any in, i bought car with a failed oil pump/balance shaft which i sorted, dont think this could cause this though,
  6. Re: diesel filter on 170 tdi
    1837 Post(s)
    Tandem pump, quite common.
  7. Re: diesel filter on 170 tdi
    #17
    Sep 2008
    thanks crasher
    once i change the pump should i leave the old filter in until i have used up and refilled the tank a few times to flush out the oil that may be in the tank and then put new filter in
    .thanks again
    colin
  8. Re: diesel filter on 170 tdi
    #18
    Sep 2008
    just had one other thought
    if oil is mixing with the diesel via the tandem pump is it possible that there is diesel in the oil,
    i will do a oil and filter change anyway to be on the safe side.
    also i'd like to thank everyone who has given me any advice on this over the last few days
    thanks
    colin
  9. Re: diesel filter on 170 tdi
    #19
    May 2007
    knee deep in clunge
    14 Post(s)
    yes change the oil and filter after these steps
    drain the tank via tripping the fuel pump fuse until the tank is empty then remove the pressure pump and clean the tank by hand and clean the pressure pump (if the pump looks like its heavily blocked by oil then flush it or replace it)
    fit a new sender/pressure pump tank o ring seal and refit
    add 5 litres of petrol but ideally a flushing agent, disconnect the fuel filter pipe and trip the fuel pump fuse again and flush till empty
    clean out the fuel filter housing fit new filter and then fit the new tandem pump and fill the tank with 10 litres of diesel
    trip the pressure pump fuse again until fuel reaches the tandem pump and start the engine
    brim the tank and check for leaks around the fuel tank o ring seal
    just a note for future reference when evaluating the sample
    Soot will show streaks and particles and will begin to separate after two hours or more.
    Oil will be uniform in colour throughout the sample. No streaks or particles will be present and no separation will occur.
  10. Re: diesel filter on 170 tdi
    #20
    1837 Post(s)
    I base my decision on how bad it appears to be, one was so heavily contaminated that I had a look inside the tank (quite easy to do) and decided to fit a new lift pump as it was filthy. After interrogating the owner it turned out he usually ran the car quite low, only putting about £20 into and empty tank each time so that sort of explained why it was so thick with oil. I would clean out the fuel filter pot, fit a new filter and pump and fill the tank to the top The question is these days, “which will cost more, filing the tank or the tandem pump?”
  1. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  2. Passat Petrol/Diesel?
    By damjee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2008, 10:26 PM
  3. 50mpg-plus Audi Diesel Sports Car Cleans Up In Geneva
    Last Post: 27-02-2008, 10:24 PM
  4. "How To" Change The Fuel Filter in a Mk4 Golf TDI
    By chris.fulton in forum Volkswagen
    Last Post: 06-02-2008, 05:43 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
