Thread: A8 Front discs and Pads
Results 1 to 10 of 13
  1. A8 Front discs and Pads
    Mar 2011
    Warrington UK
    Do you need the audi software box plugged in to activate the hydraulic caliper to change the pads and discs ?
    Thanks.
  2. Re: A8 Front discs and Pads
    Jan 2010
    Northants
    Not on the front, you only need a computer for the rear to retract the parking brake servos.
  3. Re: A8 Front discs and Pads
    Jul 2008
    I have 2005 a8 and was told you need to set new pad % in with a computer so the sensors are set correctly, can anyone confirm this is the case with front and / or rear pads as replacing myself if I don't need to plug laptop in.
  4. Re: A8 Front discs and Pads
    Jun 2006
    UK, Mids
    Yes, to do the rears, because of the EPB.
    Audi A8 - 2015 - 3.0TDI
  5. Re: A8 Front discs and Pads
    Jan 2010
    Northants
    Changing fronts is straightforward, leave the rears to a dealer/specialist unless you have vag-com.
  6. Re: A8 Front discs and Pads
    Jul 2008
    Thanks dragondownsouth, a friend has vag-com so could you tell me if its easy and what I need to do for rear pads just in case I need to replace all? Wouldn't mind trying it myself if its not technically hard.
  7. Re: A8 Front discs and Pads
    Jun 2006
    UK, Mids
    http://wiki.ross-tech.com/wiki/index..._Parking_Brake
    (REARS) Other than that, it's pretty generic.
    Also good info. here..
    http://forums.audiworld.com/showthread.php?t=2801195
  8. Re: A8 Front discs and Pads
    Jul 2008
    thanks snapdragon, doesnt seem that difficult so will try this myself. cheers, have a great xmas and new year.
  9. Re: A8 Front discs and Pads
    Jun 2006
    UK, Mids
    I suspect you only have to enter the pad thickness for the wear warning to be accurate, but not for them to work, but I may be wrong.
    When I do mine (probably later today) I will add the depth of the disc lip to the pad thickness so that the wear warning is not so belts and braces (designed for long life service regime)
  10. Re: A8 Front discs and Pads
    Jul 2008
    Thanks for help and with this I've decided to buy my own ross tech vag-com and hope its as easy as it sounds.
  1. Question front pads & discs change
    By a4ced in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-01-2011, 02:09 PM
  2. Question Front Pads & Discs - £304 good or bad
    By Adrian44 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-05-2010, 07:59 PM
  3. New discs and pads
    By Shroud in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-02-2010, 09:26 PM
  4. replacing front and rear brake discs and pads
    By ads_ali in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2009, 10:41 PM
  5. W8 Front Discs and Pads
    By Dean 355 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-12-2007, 02:39 PM
