Thread: steering lock/ column problems
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Angry steering lock/ column problems
    Sep 2007
    hi
    i have 2006 2.0 tdi 140 bhp passat and the steering started giving problems red and yellow light flashing on / off and would not start . got mechanic to clear codes and said he would order steering lock . worked fine for a day then car would not even turn over , not evev given an ignianion light just bleeping and red steering light flashing. how do i release hand brake to bring to mechanic and what is now the problem ??? please help https://www.vwaudiforum.co.uk/forum/i...ilies/zx11.gif
  2. Re: steering lock/ column problems
    Feb 2011
    newcastle
    If I remember correctly there was a recall on the steering column and the control unit. Im not 100% as the master tech at our garage used to do them all. but he changed hundreds for faults like what you are having.
    It may be worth ringing your local dealer and ask about it because we had loads of problems with them when they first came out.
  3. Re: steering lock/ column problems
    Sep 2007
    thanks
    rang dealer said there was no recall for this problem
  4. Re: steering lock/ column problems
    Norfolk
    Only a dealer can recode the new lock to the car. How did you mechanic manage that bit ?
  5. Re: steering lock/ column problems
    Dec 2010
    Chester Cheshire
    Just had mine done and as Martin says it's dealer only for this. Cost me £375 fitted, used to be a case of changing the whole column till VeeDub brought out a repair kit for it. Expensive, but better than paying a grand for a new column
    Rich
  6. Re: steering lock/ column problems
    Sep 2007
    have not brought to dealer yet as i cant get out of drive way .... how do i free the electric hand brake ??? can anybody help ???
  7. Re: steering lock/ column problems
    Dec 2010
    Chester Cheshire
    Would imagine you would need VCDS to wing the motors in
  8. Re: steering lock/ column problems
    Apr 2007
    France
    12 Post(s)
    Someone said on here recently that the steering was the subject of a recall in the States only.
    Strikes me as a bit of an 'up yours' to the Brits. Wonder where else it was a recall?
    1996 Laguna 2.2D
    1977 MGB roadster
  9. Re: steering lock/ column problems
    Norfolk
    If the rear brakes are stuck on...Take off the motor and wind the piston pusher back a few turns with a torx bit. Then put motor back. Don't use epb after this as it will need resetting.
  10. Re: steering lock/ column problems
    Jun 2010
    lisboa portugal
    why the recall is only in the States?
  1. Replies: 22
    Last Post: 18-01-2022, 05:45 PM
  2. How To DIS AND CRUISE RETRO FIT b6+b7
  3. Question knee hitting steering column
    By ted99 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-11-2010, 09:58 AM
  4. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  5. New audi s4 raises the benchmark for handling dynamics
