Thread: Car Trying to Stall in 1st Gear?!
  1. Car Trying to Stall in 1st Gear?!
    Feb 2011
    Lurgan, Co Armagh
    Hi Guys
    OK I'm now in a panic!
    Last week I picked up a 2007 A6 2.0 Le Mans Edition (manual gears). The car was running fine until this morning.
    What I have noticed three times so far is that when I select first gear and slowly release the clutch while adding some juice (as we are all told), the car starts to jump/shudder as if it is going to stall!!
    To counter you quickly push the clutch back and try again.
    It doesn’t happen every time, but as I said above it has happened 3 times on the drive into work and so is starting to make me panic!!!!
    I am able to select the gears fine (including 1st) and also I can start the car off in 2nd if there is a slight roll. This is hopefully making me think that it is not the clutch!???
    I had a quick look online and noticed a few other forums describing the same sort of probs. In one BMW forum the problem was identified as being a cracked inflow pipe meaning the car wasn’t getting the much needed air to move off in 1st gear. Others suggested a clogged up fuel filter stopping the juice getting in!
    As I said I am panicking a bit as I just bought the car, and as it was through a private dealer I will have some probs going back and saying here fix this.
    Has anyone ever come across this before, or even better knows what the prob/solution could be??
    You would be helping a new and very worried A6 owner!
    Dec 2005
    A private dealer still has to honour a warranty up to 3 months after purchase. I'd take it back to them as it seems like a fault that was present when you bought it and not a result of wear and tear etc.
  3. Re: Car Trying to Stall in 1st Gear?!
    Feb 2011
    Lurgan, Co Armagh
    Quote Originally Posted by drpellypo View Post
    Thanks for the reply.
    Is that a standard law that the dealer has to comply to?
  4. Re: Car Trying to Stall in 1st Gear?!
    3 months warranty is a statutory entitlement, you're correct - however, if the fault is considered to have been present at point of purchase, the liability for that fault is removed from the supplying dealer.
    With the fault worsening/expressing itself within a week most will opt to fix it, if only to save reputation but I certainly would not go in shouting the odds.
    My suggestion would be to visit the dealer, ask they look at the fault and see what they come up with.
  5. Re: Car Trying to Stall in 1st Gear?!
    Feb 2011
    Lurgan, Co Armagh
    Ok
    I brought the car over to my mechanic and he said what looks like the prob is that the gearbox is failing!!!!!
    Just my bloody luck! Week old car that has a prob that looks like running into £1k to fix!!
    Has anyone any experience of getting a gearbox replaced and know where I could look for a decent second hand one?
    Oh and the possibility of returning the car is def still on my mind!
    46 Post(s)
    Oh dear not a good start to your A6 ownership it must've wanted to live in France and now it's going against you
    You could always try on eBay for a 'box and get it couriered over. Best of luck
  7. Re: Car Trying to Stall in 1st Gear?!
    Feb 2011
    Lurgan, Co Armagh
    have looked on ebay, but really think that this should fall back on the seller.
    I only picked up the car last saturday and was only insured there last Wednesday, so have only had it on the road for under a week!
  1. What was your first car?????
    By RickT in forum Chat - Anything with wheels
    Last Post: 06-02-2013, 12:50 AM
  2. Warranty/ Any Renault DCi owners out there!
    By e6m6a6 in forum Chat - Anything with wheels
    Last Post: 17-01-2011, 10:26 PM
  3. Audi A3 personal review (MY10/11)
    By tlionhart in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-08-2010, 12:37 AM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
