Thread: 17964/P1556 - Charge Pressure Control: Negative Deviation
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
  1. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    Norfolk
    You need to attach logs as .zip file. The .doc file is difficult to read. It looks like your turbo is working fine. Do another log from 1000 - 4000 showing rpm, N75 duty cycle , boost pressure, MAF.
    You may have to do a couple of logs to get all the data. Just make sure rpm is with each log.
  2. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    Feb 2010
    Ashford, Kent
    change the extension back to csv and it will open in excel fine What group is n75 cycle in?
    EDIT, just looked at your site, looks like groups 1, 10 and 11 you want logged? Ill go do it now
  3. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    Norfolk
    Yep. Opens ok as .csv. I can't work out which boost is logged. Specified or actual. If you log 11, you will get rpm, boost spec, boost actual and N75%
  4. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    Feb 2010
    Ashford, Kent
    Here ya go
  5. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    Norfolk
    Is it still giving underboost fault code and has it been remapped.
  6. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    Feb 2010
    Ashford, Kent
    Yes and yes. After the first logged run it then went into limp mode and logged the 17964 code again.
  7. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    #17
    Norfolk
    The signals to the N75 valve are ok but that doesn't mean the N75 is doing what it should. It is working though. The most likely suspect is still a vacuum leak. A mityvac is the best way to test the vac pipes. A diy alternative is to VERY gently pump air into the vac pipes with a bicycle pump and see if the system holds pressure. The pressure must be little more than blowing up a balloon or you may damage something.
  8. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    #18
    Feb 2010
    Ashford, Kent
    Should it be sealed from one side to the other when the engine is off? I can blow in to one side of it (say the turbo actuator side) and air will come out the other side, but not at full pressure, leading me to believe its leaking.
  9. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    #19
    Norfolk
    Pull the pipe off the turbo actuator and blow into the pipe. You shouldn't be able to.
    Also try sucking on the turbo actuator to make sure its diaphragm is ok.
  10. Re: 17964/P1556 - Charge Pressure Control: Negative Deviation
    #20
    Feb 2010
    Ashford, Kent
    I can blow through the actuator pipe in to the N75, and if i put the hose on the actuator, i can draw a vacuum and the actuator moves easily. I'm sure my N75 has gone belly up
  1. Fault code 462c
    By veedub76 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-06-2010, 06:23 PM
  2. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  3. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  4. Newbie - first post- looking to buy!
