Thread: door wont open
  1. door wont open
    Jul 2010
    york england
    cant open front passenger door from outside anymore.its done this before but lock / unlock cured it , not this time though. theres a bad vibration coming from that area on rough roads and when music turned up so guess something else has dropped off it. any ideas ?
    really beginning to wish id never listened to the german is best hype cos in my experience so far its crap had more problems with this car in 6 months than i had in 5 years with a mondeo
  2. Re: door wont open
    Apr 2010
    Ashford, Middlesex
    Lower the window fully, then open the door using the handle on the inside; once the door is open, hold the inside handle out and then gently pull the outside handle and let it go . You might need to pull the outside handle a couple of times until it clicks back into place.
    The usual cause is passengers trying to open the door when it is locked.
    As for the noise, other than loose trim, I have no suggestions.
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  3. Re: door wont open
    Jul 2010
    york england
    thanks mate.. tried it loads of times still no luck...guess its goosed
  4. Re: door wont open
    Dec 2009
    14 Post(s)
    Fat Controllers advise is spot on . Sorry to hear that has not sorted it. Sounds like you need to remove the door card and see whats going on behind it.
    Just reading your first post. Apart from mine developing an intermitent leak its been 100% reliable.
  5. Re: door wont open
    1837 Post(s)
    New door lock unit, very common Passat 3C problem.
  1. Passat boot keeps clicking open.
    By Tomo 21 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-12-2017, 12:13 PM
  2. How do I open the petrol cap?
    By macker6464 in forum Golf MK6 - 2009 - 2013
    Last Post: 21-04-2010, 08:36 PM
  3. How To Open 03 Passat passenger door
    By Roy B in forum New Member Introductions
    Last Post: 05-11-2009, 02:59 AM
  4. How does the Quattro system work?
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
