Thread: 1.8T BFB - TPS % values?
  1. 1.8T BFB - TPS % values?
    Feb 2011
    Bewdley, Worcestershire
    I have a 2004 A4 Cab CVT 1.8T BFB engine suffering a slight flat spot
    It happens when coasting & you apply slight throttle. The first couple of mm
    of travel seems to bog the car down, push a little more & it springs into life.
    I have gone into live data and found something odd (compared to values I have seen on other cars) the TP% is reading 12.9 to 13.6 at idle climbing linear to only 86.3% at full throttle?
    I was expecting 0.8 to 100%?
    Anyone know otherwise?
    Thanks in advance
    Lloyd
  2. Re: 1.8T BFB - TPS % values?
    1837 Post(s)
    What do you get ignition on, engine not running.
  3. Re: 1.8T BFB - TPS % values?
    Feb 2011
    Thanks for fast response
    Same figures either way (running and not running) :/
  4. Re: 1.8T BFB - TPS % values?
    1837 Post(s)
    I don’t have the figures for that engine.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  3. Question Audi A4 BFB Convertable 2003 1.8T clutch master cylinder
    By PhillW in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2009, 05:12 PM
  4. Temperature sensor Audi A4 (03) 1.8T engine code BFB
    By chris_ahern in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-12-2007, 08:14 PM
