Thread: boost problems
  1. boost problems
    Aug 2008
    16618/P0234/000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    Hello, back with the leon again, (yy04cwk) 130 tdi se, the car runs fine then spirited driving cuts the boost off completely, and stopping, then restarting clears the fault, the car drives normal. but if you drive hard again, the engine management light comes on and stays on!
    really getting fed up with the car now! Help!!
  2. Re: boost problems
    Jan 2009
    towcester northants
    poss turbo variable veins seizing
    get some innotec turbo cleaner
    remove downpipe and follow instructions this cleans and frees all the internals of the turbo on the variable vein side
    good positive results
  3. Re: boost problems
    Aug 2008
    Sorry for taking so long to reply, i found the acuator vacum pipe was damaged and the actuator arm was siezed, (think this was from over time with reducing vacum), so now, touch wood!, its going great!. only thing is that so far i have been unable to get a replacement pipe from seat. the one that i was offered was straight, the one i need is "U" shaped.
    Also from previous problems, i have an Ecu for sale, wheres the best place to sell it? Thanks Grant
  4. Re: boost problems
    Jan 2009
    towcester northants
    suggest going to seat and pointing out hose on ekta
    as for the ecu put it on the for sale section on here and ebay
  1. boost problems
    By jpresto in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2009, 07:54 PM
  2. atx 1.8t boost problems
    By fastenhard in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-09-2009, 08:14 PM
  3. boost.... what boost???
    By mat_wye in forum VCDS - Help Requests
    Last Post: 06-06-2009, 08:32 AM
  4. No Boost problem ?
    By mat_wye in forum 80 - 90
    Last Post: 02-06-2009, 04:31 PM
  5. (mbc) manual boost controller on 1.8t
    By sharpy1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2008, 11:01 PM
