Thread: Rear bushes gone....?? Photos attached.
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Rear bushes gone....?? Photos attached.
    1837 Post(s)
    I use Febi 6R type bushes now for standard work, sometimes I use the Leon Cupra R type but poly bushes are great.
    Powerflex
    http://www.candrenterprises.co.uk/sh...-vw-97-06.html
    SuperPro
    http://www.candrenterprises.co.uk/sh...7-2003-23.html
    Ignore the Audi A3 bit, there seems to be an error on the page for the Golf 4 but these are the same as the Golf 4.
    Both types are lovely and tighten up the handling plush they are easier to install.
    That tool cost nearly £1K!
  2. Re: Rear bushes gone....?? Photos attached.
    May 2010
    Devon England
    [SIZE=3][COLOR=#000000][FONT=Times New Roman]
    think i will stick to removing the beam and using my air chiesel
    it looks a good bit of kit tho
  3. Re: Rear bushes gone....?? Photos attached.
    Jonny88 Guest
    Is that how much I could expect to pay for a tool to remove the bushes?!?!
  4. Re: Rear bushes gone....?? Photos attached.
    1837 Post(s)
    For one that can push out the steel bushes, yes. That is a ten tonne hydraulic ram and even that struggles, needing the help of a 3lb copper lump hammer being beaten onto the press tool at the same time as someone is putting all their weight on the hydraulic pump. The bangs the bush makes as it comes out still make me jump. The others on the market at around £150 are for removing and installing the plastic bushes which is much easier. Most garages cut out the steel bush and use the cheap tool to fit the new plastic type.
  5. Re: Rear bushes gone....?? Photos attached.
    Jonny88 Guest
    Thanks again for all your help with this guys.
    Have had the bushes sorted and the car is a pleasure to drive again! Had forgotten how uncomfortable ruined bushes make the ride.
    Cheers,
    Jonny.
  1. Rear Swing Arm Bushes
    By NickPicks in forum Golf MK3 - 1993 - 1999
    Last Post: 21-11-2010, 11:14 AM
  2. Question which are the correct rear strut top bushes?
    By cusford in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-09-2010, 01:07 AM
  3. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  4. Rear Axle mounting / Pivot bushes > Has anyone replaced? Easy? Hard? Tips?
    By Steve Foster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 01:52 PM
  5. Rear Axle Bushes
    By mkpp786 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-04-2007, 06:55 PM
