Thread: Thermostat location pls help !!!
Results 1 to 10 of 14
  1. Thermostat location pls help !!!
    Bristol
    I think my thermostat is sticking ,
    Top hose seem hot but not much fluid in them ,coolent dribbles only into coolent tank, rad and bottom hoses seems cold , heater ok ,
    I want to replace it
    But where is the dam thing located ?
    I have a Sharan 1999 1.9tdi non PD ,but guess its the same enigne in most others !!!
    some pictures be great too
    many THX
    Jul 2006
    scunthorpe
    the thermostat is located underneath the engine in the water pump housing,
    Bristol
    Quote Originally Posted by andy e View Post
    R u serious !!!!
    Mar 2007
    northumberland
    Hi ,i have a golf with the same engine ,thermostat is in the plastic housing which the top rad hose fits onto on the engine block, 2 allen or torx bolts hold it on i would have thought it will be the same ,could be wrong though.
    Bristol
    Quote Originally Posted by Stevef. View Post
    thats more like it, thx Steve,
    i did see this plastic housing just above the oil filter , and wondered if it was indeed the stat housing !! , it has various pipes going into it too , correct ? ,
    Im getting the VW manual on CD soon , so will confirm then !!!
    Jul 2006
    scunthorpe
    the thermostat housing on the 1.9tdi engine code afn is underneath the engine, i know cos i've changed mine. unless i'm australian
    Bristol
    http://forums.vwvortex.com/zerothread?id=1730221
    front left side lower of engine
    Jul 2006
    scunthorpe
    sorted now have fun changing it, a piece of advice get a thermostsat with the sealing ring that wraps round, not one that is separate, as trying to hold themo, sealing ring, and thermo cover, you need three hands
    Bristol
    andy
    I just got the VW Elsesis or what ever it is CD , and the stat is indeed in the bottom of the water pump !!!
    Did you do the job from underneath the car ?
    I got ramps and will get the car on them i think, and work from underneath !!
  10. thermostat
    Jul 2006
    scunthorpe
    that is wot i did, ramps, work from underneath car. if u have elsawin diagrams for pollen filter r in maintenance manual under dust and pollen filter won,t be online over weekend, from tonight cheers andy
  1. thermostat location
    By dean in forum Touran - Sharan - Caravelle
    Last Post: 02-01-2008, 04:22 PM
  2. Where's my thermostat?
    By AMK in forum Audi A3 - Archive Topics
    Last Post: 03-04-2007, 11:22 PM
  3. A6 2.6 V6 ('94) Thermostat.
    By karlosjackel in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 31-03-2007, 03:50 PM
  4. A4 1.8T thermostat
    By Ulsterborn in forum New Member Introductions
    Last Post: 28-02-2007, 12:44 AM
  5. mk 4 thermostat
    By Jay in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-02-2007, 02:57 PM
