Thread: Rear central brake light bulb Fault on A6 Avant 2007
  1. Rear central brake light bulb Fault on A6 Avant 2007
    Aug 2010
    Nottingham UK
    A warning light has appreared saying my rear central brake light bulb is not working. I have checked all the fuses which are OK, and have tried to look at the assembly which is very neatley fitted into the top of the rear wing over the rear screen. I've pulled the internal plastic souround off, but can not see how to get it out to check the bulbs, the connection block, the circuit via a multimeter or the assembly itself.
    Can anyone help?
    Car is A6 Avant V6 3.0 TDI Le Mans
    Oli.
  2. Re: Rear central brake light bulb Fault on A6 Avant 2007
    Chester-le-Street, United Kingdom
    have you tried poking your meter probes into the wires,through the insulation
    of the wires, in the area where they pass from the car to the rear tailgate?
    i'm only guessing but assume they would be leds, not bulbs,and your problem may be
    due to a faulty brake switch, which i believe has two sets of contacts,feeding low level
    lights / high level / ecu ?
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Rear central brake light bulb Fault on A6 Avant 2007
    Aug 2010
    Nottingham UK
    Thanks Stewy I'll have a look.
    The other main rear brake lights on the tail gate and the main body are OK, so could be.
    Yes, I think they are LEDs.
    cheers
    Oli
  1. Avant tailgate and MMI issues - connected?
    By ukandyb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-12-2014, 01:39 AM
  2. Advanced new audi a6 travels light to tackle emissions
    Last Post: 11-12-2010, 07:22 PM
  3. Esp malfunction/parking brake
    By BIGSSS in forum VCDS - Help Requests
    Last Post: 21-01-2010, 01:52 PM
  4. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
