Thread: Remove headlight switch surround
  1. Remove headlight switch surround
    Mar 2008
    Can someone please tell me how to remove the headlight switch surround and air vent. I'm trying to change the dimmer switch and the only way I can see to change it is by removeing the surround.
    Thanks,
    Jason
  2. Re: Remove headlight switch surround
    Push the knob in and turn as far to the right,you can now pull the switch out,but you do not need the switch out to replace the dimmer carefully lever switch housing out of installation frame using a flat-tip screwdriver.
  1. How To Repair your headlight switch illumination
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-12-2016, 08:59 PM
  2. "How To" remove Audi B7 glovebox
    By Ben in forum Audi
    Last Post: 19-08-2012, 11:22 PM
  3. Replies: 23
    Last Post: 20-11-2011, 06:44 PM
  4. Light switch
    By Yorky Col in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-12-2010, 11:10 AM
  5. How to remove ESP switch?
    By davidrc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-02-2008, 09:46 PM
