Thread: oil in boost pipes??
  1. oil in boost pipes??
    Dec 2008
    Hey all
    i had a leak in my intercooler so i replaced it with a new one and now the one is leaking in the same place. There seems to be a lot of oil coming from the leaks.
    Is there meant to be oil in my intake system? or have i got turbo problems?
    I got a audi a4 1.9tdi avant which has been revo remaped from 130 to 160 bhp! i was thinking if this may be why the intercoolers keep on failing?
    thought id ask the experts
    thanks and any help would be appreciated
  2. Re: oil in boost pipes??
    Jun 2010
    Lincoln, Lincolnshire
    Quote Originally Posted by chors2005 View Post
    Hey all
    You might have put too much oil in the engine the last time you topped up. So it gets sucked through the breather on the top on the cam cover. Wipe the cam cover by the breather an check it in a few days to see if that is leaking too. I have the same problem. You need to check the oil and then clean you intercooler and pipes. Also is your egr valve dripping too?
    Hope that helps
  3. Re: oil in boost pipes??
    Oct 2010
    Coventry, West Midlands
    comes down to how much oil... a little bit isnt really anything to be worried about. but if there is a lot, there may be turbo issues with the intake side. though would expect more smoke than usual out of the exhaust (as the engine burns the oil in the intake)
  4. Re: oil in boost pipes??
    Dec 2008
    Thanks for your help guys it is only a coating off oil so i thik im going to live ith it thanks again
  5. Re: oil in boost pipes??
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    As carspark says a film of oil is not an issue, in fact quite normal but if it's flooding out you could be looking at turbo.
    Wouldn't concern yourself unless you are having to keep topping up due just to this
  1. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
  2. Answers from an oil expert...
    By oilman in forum Archive posts
    Last Post: 20-01-2008, 05:30 PM
