Thread: PD fuel filter change?
  1. PD fuel filter change?
    Jan 2006
    Near Basingstoke
    Need to change mine as it has done 30K and as per other post car is not running well. However I have heard that once changed I should not keep cranking the engine to prime it, I should prime it first. Any suggestions as to how. I have a large 50 ml syringe, but that's about all for 'sucking'
  2. Re: PD fuel filter change?
    Pembrokeshire
    22 Post(s)
    turn the ignition on, hear the in tank pump run, do this several times, then start. it will probably cut out, so prime again with the pump until it runs. leave ticking over for a few minutes then drive
  3. Re: PD fuel filter change?
    Jun 2006
    UK, Mids
    Just fill the new one with diesel to the brim.
    You can also suck at the filter by removing a small bolt on top if you have the correct vacuum tool.
    All models have a pump in the tank, but some models/years don't have a delivery pump there, these don't provide any supply to the front of the car, they merely fill an in-tank reservoir and scavenge the corners of the odd-shaped tank.
    Audi A8 - 2015 - 3.0TDI
  4. Re: PD fuel filter change?
    Jan 2006
    Near Basingstoke
    would it be a good idea tio clamp the flow pipes beforer disconnecting to stop the fuel being sucked back into the tank?
  5. Re: PD fuel filter change?
    Apr 2009
    Quote Originally Posted by bk.bas99 View Post
    I wouldn't bother
    Regards
    Jim
  6. Re: PD fuel filter change?
    Hampshire
    When I changed mine it started again without any problems or any special measures.
  7. Re: PD fuel filter change?
    May 2009
    This is scheduled to be done every 40,000 miles. It is a relatively easy task, and while many people recommend filling the new one with fresh diesel, this shouldn't be necessary as turning the ignition on a couple of times (without starting the engine) should prime it.
    Replacing the filter and trying to start the engine (without priming it first) is a good way of checking the condition of the battery, so if you've got a spare, or a means of recharging, do this first!
  1. "How To" Passat B5.5 TDI Servicing
    By Col in forum Volkswagen
    Last Post: 02-05-2015, 04:11 AM
  2. Replies: 2
    Last Post: 24-11-2010, 11:35 PM
  3. "How To" 2.0 PD 140 Passat B6 Fuel Filter Change
    By DSG4ME in forum Volkswagen
    Last Post: 19-08-2010, 01:03 AM
  4. Change fuel filter
    By vroooOOOM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-07-2009, 02:12 PM
  5. How do i change the fuel filter 2004 Golf 2.0 TDI
    By daveaustin in forum Archive posts
    Last Post: 17-04-2007, 11:36 PM
