Thread: Speed limiter!! One last chance before VW reprint me of £1000!!!
Results 1 to 10 of 12
  1. Speed limiter!! One last chance before VW reprint me of £1000!!!
    Jul 2008
    WILTSHIRE
    Hi all, I'm giving this one last chance to see I'd anyone out there can help me with removing my speed limiter. I have had 5 companies now try to remove it without success. VW want £1000 to do it by replacing the ECU. I've tried everything. Has anyone got any ideas????
  2. Re: Speed limiter!! One last chance before VW reprint me of £1000!!!
    cornwall
    Hi mate my lt35 has a limiter set at 75mph and the only way to remove is to replace the ecu ,they can be set lower but not increased.
    I dont mind mine set at 75mph ,any faster and its over reving the engine.
  3. Re: Speed limiter!! One last chance before VW reprint me of £1000!!!
    Did you take the van to Shark 90?
  4. Re: Speed limiter!! One last chance before VW reprint me of £1000!!!
    Another thing you must take into consideration,if you should replace the ECU,it is ordered by the VIN,which means the ECU is preset,to 75mph,from the factory
  5. Re: Speed limiter!! One last chance before VW reprint me of £1000!!!
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    `Lee It `is correct... i used to set them for my dealer, daft idea i know !
    Alan.
    VW T6 150 DSG Camper £££
  6. Re: Speed limiter!! One last chance before VW reprint me of £1000!!!
    Jul 2008
    WILTSHIRE
    75mph would be bliss! Mine is set at 56 as it is a lt46 but I have had it downplated so no longer a legal requirement. I can't understand why mine is such a problem. Everyone who I have sent the ecu to has initially said they could do it but all have been unable to.
    No eshrules, I haven't tried shark 90 I will contact him.
    I have been to VW, that's how I know a new ECU is their solution but at a price. They did say that they could supply one un-set though.
  7. Re: Speed limiter!! One last chance before VW reprint me of £1000!!!
    cornwall
    You could try getting one from the breakers with the same engine code.?
  8. Re: Speed limiter!! One last chance before VW reprint me of £1000!!!
    Jul 2008
    WILTSHIRE
    Thanks Lee, I did buy one from eBay with all the same codes but that turned out to be set at 56 too. Not had much luck.... I was told that one from a lt35 even with a different part number would still work but would need to be coded though Ive not confirmed this with VW.
  9. Re: Speed limiter!! One last chance before VW reprint me of £1000!!!
    Oct 2005
    Quote Originally Posted by charliebucket View Post
    He replied to one of your earlier threads saying he'd have a look and if he couldn't there'd be no charge.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=79684
    Although that was in 2009!
  10. Re: Speed limiter!! One last chance before VW reprint me of £1000!!!
    Hi, charliebucket, just off subject a bit but i thought might be worth a mention.
    I dont know how many miles your engine has done or if indeed it is the original and untouched likewise as what you will use the vehicle for, but, the vehicle has not able to do more than 56 since its birth then to suddenly be able to do 70+ at revs getting towards and over the 3 thou rpm, and all turning pieces wheather engine , g/box/ or axle and bearings are able to rotate faster may make the £1000 for a ecu look like pocket money in repair bills later, may be talking out me tree here but thought might as well mention it
  1. New guy with a headache LT46 speed limiter
    By themills in forum The Commercial Range
    Last Post: 19-10-2022, 09:53 AM
  2. Golf GT 7DSG review after 6,500 miles
    By slo007 in forum Golf MK6 - 2009 - 2013
    Last Post: 14-11-2010, 12:05 PM
  3. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  4. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  5. Speed Awareness Course
    By prolfe in forum Chat - Anything with wheels
    Last Post: 08-06-2007, 01:35 PM
