Thread: Canbus recoding help
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Canbus recoding help
    Mar 2010
    salisbury wilts
    hi ive got an aftermarket nav headunit ive got the "C" gateway. and i what to replace it with a "J+" gateway to sort the battery drain problem. i have vag.com and was wondering if anyone had a step by step guide to what coding needs to be done. thanks.
  2. Re: Canbus recoding help
    Mar 2009
    York
    Is your 'aftermarket' head unit a VW RNS/RCD model? If not, I didn't think that any third party stereo, regardless or nav or not, was affected by the battery drain problem (since you'd use ISO adapters)...
    Can you let us know what the model is you want to install - as far as I knew, only the later RCD 310/510 etc models were affected by battery drain issues...
    hth
    edit: just seen your other post in the other thread. You might want to ignore this post then!!!!!!
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  3. Re: Canbus recoding help
    Norfolk
    Quote Originally Posted by manity View Post
    There is a guide and download practice spread sheets on my site.
  4. Re: Canbus recoding help
    Mar 2009
    Sleaford, Lincs, UK
    Will this actually solve it for our units though? As the car will still be looking for a genuine radio? Is it only revision J+ that will work then??
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  5. Re: Canbus recoding help
    Mar 2010
    salisbury wilts
    mm good point might give it a miss then
  6. Re: Canbus recoding help
    Mar 2009
    Sleaford, Lincs, UK
    Lets hope the dude with the fix will email us back sharpish!!
    Saying that, some people do not get battery drain... What year is your Passat Manity? Mine's 07, Richie's is 06 I believe..
    It would be interesting to see if people who have these units that do not get battery drain have higher revision Gateways??
    Deep Pearl Black
  7. Re: Canbus recoding help
    Feb 2010
    Louth Ireland....
    Going to check mine tomorrow, not even sure if i am getting drain. Has only happened once and thinking back it was around the time the battery packed up. The car is used everyday so i cant even let it stand for a few days to test it......Multimeter will tell the story i hope.
    Ex Passat B6 owner......to many retrofits to mention !
  8. Re: Canbus recoding help
    Feb 2010
    Louth Ireland....
    Found this earlier, have a read..........
    Alexsnowflake 09-02-2009 12:42 PM
    Battery Drain Issue Solution
    It has been more than 10 days since I've tested a solution in 4 cars that had the battery issue problem, I guess it's time to share with you how it works being the fact that none of these cars had the leak.
    Myself and a group of guys from a Jetta/Passat Club in Argentina (http://www.jetta-passatclub.com) bought 10 units from Witson and we verified that 5 out of 10 had the battery drain issue.
    Witson offered their warranty only if we place a new order. Unbelievable !
    A chunk of these units went out to the market and had this fault when connected in a car with Can Gateway 1K0 907 530 L or newer than L.
    So we bought 5 Can modules for the units from Witson, we asked them for the new ones, the ones that are being installed on the mk4's but they sent us the same old modules. After changing it fault was not fixed as you can imagine.
    Anyway, due to lack of Wiston support in any way, I did some research myself and observed that measuring the total current consumption with the car closed and locked (also the hood) the value was 680mA. Then measuring the consumption of the unit itself was very low. That gave me the idea the current drain can be achieved to the Can Gateway querying the unit and not being able to detect it, that process goes on and on.
    The solution was to use a small 12V relay to interrupt the CAN Hi cable from the unit (orange color) to avoid that situation. The idea is to keep connected the orange cable when the ignition key is in position 1 or 2 and interrupted when key it's in position 0, out or the car locked.
    To do that the way to power the relay goes like this: one end of the relay coil needs to be connected to ground (black cable) and the other end can be connected either to the lighter or if your car has climatronic you can use the green/black cable at the rightmost on the climatronic connector.
    By doing this the total current dropped to a value of 20-30 mA which solves the problem.
    http://golfmk5.com/forums/printthrea...pp=22&page=187
  9. Re: Canbus recoding help
    Mar 2010
    salisbury wilts
    right got a email back from them today here it is...
    Dear friend
    The “relay solution” has installed in a lot of cars ( vw golf / tiguan / eos,..)
    with 100% success !
    First to support my work , please make a gift 30 $ (USD)
    To my paypal account : tpapo@sch.gr ( Tom Papoutsas)
    Then I will send you via email the "how to" pdf file ( 5 pages )with details and photos
    For issues about battery drain problem & measurement look at my page
    http://www.naviexperts.gr/Battery%20drain%20fix.html
    Regards
    Tom
    looks like 30 dollars is wanted b4 he sends out the info.
    Tomboy i have a 07 plate sport my canbus finishes with "C" im not even sure i have the drain issue the longest ive left it so far is 3 days over the xmas period when it was bl@@dy cold and although it turned over slower it did start ok.
    alot of the people who have had the drain usually flattens the battery in two to three days..
  10. Re: Canbus recoding help
    Mar 2009
    Sleaford, Lincs, UK
    Richie, what does your post mean? I don't understand?
    Deep Pearl Black
  1. Question 2000 facelift Sharan..CANBUS ??
    By fastbikes76 in forum Touran - Sharan - Caravelle
    Last Post: 28-04-2010, 10:00 PM
  2. Canbus to USB Diag cable
    By Peter D in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-04-2009, 09:40 AM
  3. Canbus Audio Interface ignition feed...
    By djsky in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-05-2008, 10:24 PM
  4. canbus socket location?
    Last Post: 28-02-2008, 01:28 AM
  5. CanBus?
    By b0redom in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-11-2007, 07:13 PM
