Thread: 2002 Passat 1.9tdi turbo blown hose
  1. 2002 Passat 1.9tdi turbo blown hose
    Jan 2011
    lincs uk
    Hi, newbie to forums so will appollogise now for any misderminers.
    I have a 2002 1.9tdi when i get to 3000 Revs one of the Hoses blows off to the right of the engine. hose approx 80mm dia.
    what is causing this to happen ( i am presuming the turbo is kicking in). when this happens the engine sounds a lot louder and ruffer. any ideas?
  2. Re: 2002 Passat 1.9tdi turbo blown hose
    Norfolk
    The hose connector is worn. You need a new hose.
  3. Re: 2002 Passat 1.9tdi turbo blown hose further problems
    Jan 2011
    lincs uk
    Hi i have startede having Abs Problems , i have vag com-ed my car following fault codes have been highlighted. pd unit injector , cylinder 1 (N240) Electrical malfunction. P1666-35-10 INTERMITENT.
    also abs Load signal error from ecu P1857-35-10 Intermitent. can anyone shed some light on these codes for me. all of the wheel sensors are functioning Any Ideas? Thanks
  4. Re: 2002 Passat 1.9tdi turbo blown hose further problems
    Norfolk
    I would change the injector loom, clear the codes and see what happens. that's probably the cheapest first option.
  1. VW Passat Tdi Sport 130 2002 - Loss of Power - Turbo not kicking in
    By iworld in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2013, 07:34 PM
  2. Please Help Turbo failure again-help please!!!!!!!
    By Tyanu888 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2011, 09:18 PM
  3. Please Help Passat 130 TDI Turbo Hose Removal
    By stevem61 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2010, 09:51 PM
  4. A6 Turbo Needed for a 1.9Tdi PD130 2003 53 reg,
    By General5*Hague in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-04-2008, 06:01 PM
  5. Replies: 0
    Last Post: 10-11-2007, 08:05 PM
