Thread: Remove the steering wheel
  1. Remove the steering wheel
    Oct 2010
    Middlesbrough
    Can anyone tell me how to remove the steering wheel from a B7 3.0TDI tip so that I can fit a new stalk.
    Oct 2010
    Here And There
    As far as health and safety and all that lark, it is recommended to disconnect your battery, I personally dont.
    Turn your steering until you can see 2 little removable sections on the rear of your wheel, pluck them out and in there, you will find a 30 torx screw, losen these screws ( they will not come right out ) and that will release the airbag. Make sure your key is only at the first click if you still have your battery connected ( no ignition lights on )
    Remove the clip on the end of the airbag wiring loom by sliding the red clip on the loom towards you and at the same time pulling gently. Now you will see the multi spline bolt holding the main wheel on. Remove this and hey presto.
    Be aware not to :
    Turn the airbag slipring while the steering wheel is removed.
    Turn your ignition ON with the airbag removed ( it will store a fault in your airbag unit and make your warning light stay on )
    Maybe someone can tell you the torque settings for the spline but be carefull not to over tighten it as it will ring off very easy.
    Sent from my iPhone using Tapatalk as I cant be ***** turning on my laptop !
  3. Re: Remove the steering wheel
    Jul 2009
    Belgium
    i think the procedure is the same good luck http://www.audiworld.com/tech/int.html
    Oct 2010
    Here And There
    Quote Originally Posted by sline002 View Post
    That is a cool link. I would maybe go by it as far as health and safety goes lol.
  1. steering wheel controls
    By dark-snake in forum VCDS - Help Requests
    Last Post: 11-10-2010, 02:39 PM
  2. Question Retrofitting a multifunc steering wheel
    By *JonCage in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-01-2010, 02:55 PM
  3. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  4. Replacement of 4spoke to 3spoke steering wheel
    By petera1979 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-01-2008, 10:41 AM
  5. Steering Wheel Removal
    By Davidj241 in forum Passat - Archive Topics
    Last Post: 25-05-2007, 02:18 AM
