Thread: Golf 1.4 petrol speedo stopped working
  1. Golf 1.4 petrol speedo stopped working
    Jan 2009
    Dublin, Ireland
    Lads
    I have a 1.4 petrol Golf that the speedo has stopped working on.
    I believe the speedo is driven by a sensor on the back of the gearbox.
    The clutch was replaced a while ago, and the speedo wasn't working when I got it back. I took the car back, they fiddled with the wire, and it was working again.
    I drove it for a few weeks, and sometime during that time, the speedo would occasionally drop to 0 mph. Then it stopped working altogether.
    I thought it was related to the clutch change - perhaps the sensor was damaged in the work, but I took it back to your man, and he put a spare sensor in, and it didn't change the situation. I suppose he could have given me a dodgy spare sensor?
    Do the speedos go bad in these cars, or is it almost 100% likely to be a dodgy sensor????
    I have the NCT tomorrow morning, so looks like I will be rescheduling...
    many thanks in advance.
    2002 Audi A6 1.9 tdi Sport saloon - 160,000 miles
    99 VW Golf 1.4 base hatchback - 120,000 miles
  2. Re: Golf 1.4 petrol speedo stopped working
    1836 Post(s)
    Possibly damaged wiring under the battery.
  3. Re: Golf 1.4 petrol speedo stopped working
    Jan 2009
    Dublin, Ireland
    Cool. I will check it out.
    Thanks!
  4. Re: Golf 1.4 petrol speedo stopped working
    Jan 2009
    Dublin, Ireland
    So I pulled the battery out, and had a quick look. The wiring loom looks like its been exposed a little to the effects of the battery, but doesnt look too bad at all.
    Crasher, when you say damaged wiring under the battery, do you reckon I'd have to pull the loom apart to see the damage? Is it common, or known to happen is it, that the wiring under the battery deteriorates? Speedo is the only thing not working. Do you know if the clock is prone to failing? Is it coded to the car, or can I just bung a new one in from the wreckers? If it is coded, is it difficult to recode??
    I suppose I would. NCT is 830 am tomorrow, so am going to fail, but at least I'll know if anything else needs doing.
  5. Re: Golf 1.4 petrol speedo stopped working
    1836 Post(s)
    Yes you have to dig in there and find the white/blue to the speedo sensor and check that the black/green to the sensor has an ignition live and that the brown has an earth.
  1. 1.4 TFSI or 1.6 TDI?
    By releaseyourself in forum A1
    Last Post: 10-02-2011, 10:38 PM
  2. Volkswagen launches new range of highly efficient golf models
    Last Post: 03-07-2009, 07:48 PM
  3. Replies: 0
  4. Vw Golf 1.4 or 1.6 Mods.???
    By cocobench in forum Golf MK4 - 1999 - 2004
    Last Post: 01-06-2009, 12:29 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
    Last Post: 19-11-2005, 05:57 PM
