Thread: Retrofitting Multi Funtion Steering Wheel - covers everything including part numbers and vagcom coding
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
  1. Retrofitting Multi Funtion Steering Wheel - covers everything including part numbers and vagcom coding
    Oct 2010
    Here And There
    Hi folks. I was not too sure where to post this so I have put it here and in the wanted section.
    I am going to buy a multi function steering wheel off Ebay with the red SLine badge on the bottom. Brand new for £150.
    First of all, I was going to ask if anyone on the forum is selling one or knows of any of the flat bottom steering wheels that they could offer me instead ?
    Second thing is that I just have the normal wheel on mine, I take it that I might just have to buy an extra loom for the steering wheel to work off the new buttons and possibly a recode with VCDS ?
    Any help will, as always, be very much appreciated
    Sent from my iPhone using Tapatalk as I cant be ***** turning on my laptop !
  2. Re: Multi Funtion Steering Wheel
    Oct 2010
    Here And There
    Ok, I bought this one in the end from Ebay after trying a few sponsers from the site but they didnt have them. http://cgi.ebay.co.uk/ws/eBayISAPI.d...:X:RTQ:GB:1123
    Sorry, ignore that link as the seller changed the item number. It is a brand new Audi A4 wheel the exact same as that link but without the paddles as my car is a manual.
  3. Re: Multi Funtion Steering Wheel
    May 2007
    knee deep in clunge
    14 Post(s)
    2 0 0
  4. Re: Multi Funtion Steering Wheel
    Oct 2010
    Here And There
    Quote Originally Posted by a8 tech View Post
    WOW A8, thats an amazing walk through and very informative indeed.
    So ill first need to check my air bag slip ring to see if it has all 20 pins occupied on the loom side. If not, ill need a new loom and slip ring.
    Secondaly purchase the steering control module that you mentioned.
    Then ill need to recode them all.
    Is this correct ?
    When you mention the part numbers for the control unit and the loom, you say either Q or R for control unit or A or B for slip ring. Why and how do I know which I need ?
    I never get a chance to thank you by the THANK button A8, as im normally just on iphone, but im on the laptop now so I have today
    Does this sound a fair price for the slip ring considering its damaged ? Are they expensive new A8 http://cgi.ebay.co.uk/AUDI-A4-AIRBAG...item2a0ad90f6f
  5. Re: Multi Funtion Steering Wheel
    May 2007
    knee deep in clunge
    14 Post(s)
    post a scan for address 16 to identify your steering control unit
    if it ends with Q or R then that's ok
    the loom for the muti function will defiantly require replacing
    then its just a case of identifying if you have the correct slip ring
    coding is very easy
    you adjust the code in address 16 to enable the mfsw controls
    if you have radio you adjust the code to add
    if you have telephone same again
    i will walk you through it
    Thanks for the thanks on the dis and cruise thread, its the first ever thanks and it been used by 1000's of people including ebay sellers
    The thread has never made sticky status although it covers B6 & B7 DIS AND CRUISE PLUS MFSW
    Glad to see someone shows a little appreciation lol
    Oct 2010
    Here And There
    No problems at all A8, you have been extremely helpfull tonme over the time of being on the forum and I very much appriciate it indeed. I take it that this is good news then ?
    What do you think about the above ebay link for the slip ring ? Stay away ?
  7. Re: Multi Funtion Steering Wheel
    May 2007
    knee deep in clunge
    14 Post(s)
    control unit is spot on
    whip the airbag off and disconnect the yellow connector off and count the pins on the slip ring
    ebay slip ring has abroken lug so leave it, try german ebay wink wink
    off line for a few hours now
    Oct 2010
    Here And There
    Ok, done that and I think this is where my luck runs out
    It has 12 pins of which only the top row of 6 are occupied.
  9. Re: Multi Funtion Steering Wheel
    May 2007
    knee deep in clunge
    14 Post(s)
    You need to upgrade the steering angle sensor
    I have posted your picture to the dis thread to help others
  10. Re: Multi Funtion Steering Wheel
    May 2007
    knee deep in clunge
    14 Post(s)
    The ebay link I removed turned out to be the A8 slip ring
    this is the correct p/n
    http://i836.photobucket.com/albums/z...g?t=1295206799
  1. VW Polo Speedo bouncing around
    By naf536 in forum VCDS - Help Requests
    Last Post: 08-01-2016, 12:46 PM
  2. Multi Function Steering Wheel
    By royster in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-01-2011, 11:06 PM
  3. Retro Fitting Steering Wheel & Front Sensors?
    By Mike2.0TQ in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-01-2011, 06:10 PM
  4. Vag diagnostic tools. A summary.
    By Ben in forum VCDS - General Questions
    Last Post: 16-03-2008, 10:22 PM
  5. VAGCOM experts !!!!
    By cbrpaul in forum Archive posts
    Last Post: 28-07-2007, 06:34 PM
