Thread: Retrofitting Multi Funtion Steering Wheel - covers everything including part numbers and vagcom coding
Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 70
  1. #21
    Oct 2010
    Here And There
    Yea, the tapatalk really is easy. When you use it you will see. Quite addictive really ! The way that it logs you on, you get to see every recent post too. I like it.
    Sent from my iPhone using Tapatalk as I cant be ***** turning on my laptop !
  2. Re: Multi Funtion Steering Wheel
    #22
    May 2010
    Devon England
    Quote Originally Posted by Bangor Lad View Post
    i will have to give it a try
    Oct 2010
    Here And There
    Having a little trouble with the ring A8, will 4E0 953 541 A do or will it have to be B ?
    Or this ebay item 120673704099
  4. Re: Multi Funtion Steering Wheel
    #24
    May 2007
    knee deep in clunge
    14 Post(s)
    Airbag slip ring 4E0953541A or B will do the job
    Oct 2010
    Here And There
    Quote Originally Posted by a8 tech View Post
    thank you.
    For future searchers, A superseeds to B ( they are the same part )
    Oct 2010
    Here And There
    coding is very easy
    you adjust the code in address 16 to enable the mfsw
    i will walk you through
    A8 Im going to do the fit on Saturday. Can you help ? I have bluetooth through the car already
  7. Re: Multi Funtion Steering Wheel
    #27
    May 2007
    knee deep in clunge
    14 Post(s)
    http://wiki.ross-tech.com/wiki/index...g_Wheel#Coding
    change the code to x4xxx:
    http://wiki.ross-tech.com/wiki/index...aration#Coding
    xxx1xxx:
    http://wiki.ross-tech.com/wiki/index...tion_II#Coding
    0xxxxx? add 4 to this digit
    http://wiki.ross-tech.com/wiki/index.../8HE%29#Coding
    channel 062: CAN-Databus Infotainment (Installation List)
    add value 2 = Telephone (Optional)
    this is the dash bus to show the phone on the dash but it might already be set
    let me know how you go on and if you get stuck use the label files on vcds, its always easier when the vcds is connected to explain the code changes
    Oct 2010
    Here And There
    Fantastic info A8 as always !!
    Changed the control unit coding as you described and my wheel is now lighting up and controlling the radio !!
    Thank you soo much again.
    Do you know what the MODE button, the HEAD with waves coming out of his mouth and what the right hand rolling switch should do when pressed down as none of these operate ?
  9. Re: Multi Funtion Steering Wheel
    #29
    May 2007
    knee deep in clunge
    14 Post(s)
    mode switches from radio to phone
    the other is push to talk for voice control of the phone
    pair your phone and retry
    if it still not working revisit the code changes in address 77 and 16
    at work so quick answer
    address 16Audi A4 (8E) Steering Wheel
    From Ross-Tech Wiki
    Jump to: navigation, search
    Contents [hide]
    1 Coding
    2 Adaptation
    2.1 Channel 081: Vehicle Data Learning
    Coding
    0?xxx: Steering Wheel
    0 = Standard (without Multifunction)
    1 = 3-Spoke Steering Wheel (Sport Steering Wheel)
    2 = Multifunction Steering Wheel with Radio Control
    3 = Multifunction Steering Wheel with Radio/Telephone Control
    4 = Multifunction Steering Wheel with Radio/Telephone/Voice Control
    5 = Multifunction Steering Wheel with Radio/Voice Control
    0x?xx: Options
    +1 = Tiptronic
    0xx?x: Board Computer & Cruise Control
    0 = Board Computer & Cruise Control not installed
    1 = Board Computer installed
    2 = Cruise Control installed
    4 = Board Computer & Cruise Control installed
    0xxx?: Rear Wiper (Chassis)
    1 = Rear Wiper not installed (Sedan/Cabriolet)
    2 = Rear Wiper installed (Avant)
    make sure multifunction with radio and phoneand voice control added
    0?xxx ? should be value 4
    go to
    address 77
    make sure bluetooth is activated
    Adaptation
    Bluetooth
    [Select]
    [77 - Telephone]
    [Adaptation - 10]
    Channel 133
    [Read]
    0 = Bluetooth OFF
    1 = Bluetooth ON
    then check this
    Hands Free Function
    [Select]
    [77 - Telephone]
    [Adaptation - 10]
    Channel 134
    [Read]
    0 = Hands-free active while Bluetooth connection is active but without cell phone engaged
    1 = Hands-free only active with cell phone engaged
    recheck code in 77
    http://wiki.ross-tech.com/wiki/index...ion#Adaptation
    0xxx?xx: Installation List
    1 = Diagnostics via CAN
    2 = Multi-Function Steering Wheel, Diagnostics via CAN
    3 = Head Unit (e.g. RNS-E), Diagnostics via CAN
    4 = Multi-Function Steering Wheel, Head Unit (e.g. RNS-E), Diagnostics via CAN
    5 = Diagnostics via K-Line
    6 = Multi-Function Steering Wheel, Diagnostics via K-Line
    7 = Head Unit (e.g. RNS-E), Diagnostics via K-Line
    8 = Multi-Function Steering Wheel, Head Unit (e.g. RNS-E), Diagnostics via K-Line
    change this to value 6
    post all your codes up or a full log and i will look after
    better go boss is here arghhhhhhhhhhhhhhhhh
    2 0 0
  10. #30
    Oct 2010
    Here And There
    Ok, I got it working A8 Thank you very much indeed. I have taken pictures of the adaption values and have done a full scan to show what codings that I have used. Thank you sooo much again.
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E36A087331 Mileage: 183580km/114071miles
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8E0 910 115 Q HW: 8E0 907 115 D
    Component: 2.0l R4/4V TFSI 0030
    Revision: --H10--- Serial number:
    Coding: 01040003180F0120
    Shop #: WSC 00590 210 87518
    VCID: 2F6618D4C79B
    No fault code found.
    Readiness: 0010 0000
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
    Component: ESP8 quattro H05 0120
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004526
    Shop #: WSC 06335 000 00000
    VCID: 2952F6CCF97F
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BJ
    Component: A4 Klimaautomat 2832
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6AD0C9C03CF9
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 L
    Component: int. Lastmodul ECE 0504
    Coding: 00001
    Shop #: WSC 06334
    VCID: 3B7E3C8403E3
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H11 3530
    Revision: 91H1135 Serial number: 0036M0073VK6
    Coding: 0033622
    VCID: 3B7E3C8403E3
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0601
    Coding: 04041
    Shop #: WSC 06335
    VCID: 41824E6C610F
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 951 F HW: 8E0 920 951 F
    Component: KOMBI+WFS 4 H12 0110
    Revision: 0110 Serial number: 00000000000000
    Coding: 0007441
    Shop #: WSC 00012 044 13423
    VCID: 2D5A02DCCD97
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0804
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDE4CC4B303
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 CA
    Component: Komfortgerát T3B 3332
    Coding: 06911
    Shop #: WSC 06335
    VCID: 72E0D1A01429
    Part No: 8E2959802F
    Component: Tõrsteuer.FS BRM 0406
    Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0205
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0205
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0205
    1 Fault Found:
    01560 - Passenger Door
    37-10 - Faulty - Intermittent
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 D
    Component: concert II GRO 0004
    Coding: 01027
    Shop #: WSC 06335
    VCID: 2854F3C8E275
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 B HW: 8E0 919 283 B
    Component: Parkhilfe 4-Kan H06 0020
    Revision: 00H06000 Serial number: 00067802020524
    Coding: 0000104
    VCID: 2F6618D4C79B
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 C HW: 8P0 862 335 C
    Component: FSE_255x BT H18 0160
    Revision: 00000001 Serial number: 00000000287735
    Coding: 0001622
    Shop #: WSC 00590 210 03417
    VCID: 36682DB038C1
    2 0 0
  1. VW Polo Speedo bouncing around
    By naf536 in forum VCDS - Help Requests
    Last Post: 08-01-2016, 12:46 PM
  2. Multi Function Steering Wheel
    By royster in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-01-2011, 11:06 PM
  3. Retro Fitting Steering Wheel & Front Sensors?
    By Mike2.0TQ in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-01-2011, 06:10 PM
  4. Vag diagnostic tools. A summary.
    By Ben in forum VCDS - General Questions
    Last Post: 16-03-2008, 10:22 PM
  5. VAGCOM experts !!!!
    By cbrpaul in forum Archive posts
    Last Post: 28-07-2007, 06:34 PM
