Thread: et35 or et45????????
  1. et35 or et45????????
    Mar 2010
    liverpool
    i have rs6 18's on currently with an et35. they sit flush with edge of wheel arch which i like. have been offered rs6 19's with an et45, will they sit further back in the arch so look slightly set back from edge of arch. your help is appreciated
  2. Re: et35 or et45????????
    Jun 2010
    gosport UK
    Quote Originally Posted by aaudi4 View Post
    I would say go for the 19's.... can i have first dibs on your 18's please.. Serious.
    Et 45 or Et42 is more or less standard i believe
    Corsa - But want an Audi!!!
  3. Re: et35 or et45????????
    Mar 2010
    liverpool
    hi, ye both will fit but trying to establish how wheel will differ in way it sits in wheel arch. i like the look of mine sitting on edge of arch, gives it a good look and dont want to buy others if sits back and dont have same look.
    Jun 2010
    gosport UK
    I think it depends, if they are same width then tyres will sit in under the arches. The current look you have is what I'm after. If it were me I would stick with current setup.
  5. Re: et35 or et45????????
    May 2007
    Under the Forth Bridge
    Try this for size - makes it all pretty straightforward. Enter details of current wheel (width and offset) and that on new wheel and hey presto....
    http://www.1010tires.com/wheeloffsetcalculator.asp
    Current : B6 (54) 1.9tdi Quattro Sport Avant (250k and counting), 8L (02) A3 1.9tdi Quattro Sport (5dr) (130k and counting) VW Touran 2016 2.0tdi Family SE (don't ask!)
    Previous : B6 (03) 1.9tdi Quattro SE, 8L (03) A3 1.9tdi SE (5dr)
  6. Re: et35 or et45????????
    Mar 2010
    liverpool
    cheers that answers my question
  7. Re: et35 or et45????????
    Mar 2007
    Lancashire
    If you like the new alloys get some spacers. 10mm should do you all round. I'm assuming the rim width is the same? Even 5mm spacers may do. From the calculation used above you should be able to get spacers to take make up for the offset. Get hubcentric ones which are bolt through. You will also need new bolts. I have spacers on my TT, 10mm fr and 15mm rr. Transforms the look of the car!
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
    Jun 2010
    gosport UK
    I used 10mm front 15mm rears on my A4 and looked fantastic. But the rears rubbed occasionally on arch, then 1 passenger in rear seats and it was constant. Does look good tho. That's why if I buy new wheels I'm going max. Et35. All round.
  9. Re: et35 or et45????????
    Mar 2010
    liverpool
    yes i think spacers are way to go. as i say currently have 18's with et35 and sit on edge of arch and look great. would not want to move wheels in. if can work out how to load up pictures have took some of the car to show.
  1. What size tyres should i go for? 19x8.5 ET45
    By kreative in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-07-2010, 06:59 PM
  2. Wheel Spacer ET45 to ET37 - Legality?
    By aprildavy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2009, 01:00 PM
  3. Wheels - this might be helpful
    By renamecor in forum Touran - Sharan - Caravelle
    Last Post: 14-12-2009, 02:15 PM
  4. Will ET54 alloys fit ET45 Audi A6
    By raf_man in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-09-2009, 11:47 PM
  5. 17" Mk1 Audi TT Competition polished wheels - offset needed
    By unclefester in forum TT - 8N Forum - 1998 - 2006
    Last Post: 28-02-2008, 10:01 AM
