Thread: Oil pump chain smashed thru alloy case and discussion on replacement oil pump conversion kit for BLB engine
Page 31 of 31 FirstFirst ... 21293031
Results 301 to 302 of 302
  1. Re: Oil pump chain smashed thru alloy case and discussion on replacement oil pump conversion kit for BLB engine
    Dec 2016
    Hungary
    I live in Hungary, and our mechanic is a good friend of the family. He helped us a lot in solving this issue. He found this Audi-guru guy here that sells these balance modules. He converts the hex to 10mm himself, and he doesn't sell the modules without doing it, because it's just a matter of time before it fails if it's left stock. He seemed like a very professional and honest guy, which is very rare nowadays.
  2. Re: Oil pump chain smashed thru alloy case and discussion on replacement oil pump conversion kit for BLB engine
    Apr 2015
    Damascus, Syria
    I would have more faith in this 10mm modified shaft than any replacement kit, even with the longer shaft. Looks like a winner to me. Surely VAG have changed the oil pump set by this stage in the 2.0 Ltr engines? Does anyone have definite info about when ( or even IF) such changes took place? IE, if I buy any VAG 2.0 ltr diesel driven veh, say from 2012-2013 onwards, would I be safe enough? Or has this problem persisted in even newer models?
    Cheers: !!!
    Jim.
