Thread: Oil pump chain smashed thru alloy case and discussion on replacement oil pump conversion kit for BLB engine
Page 2 of 31 FirstFirst 123412 ... LastLast
Results 11 to 20 of 302
  1. Re: big problem oil pump chain smashed thru alloy case
    Aug 2009
    hexham uk
    Re a8 tech,s reply. Surely the conversion is the other way round? From chain drive to gear drive. There is threads on here for fitting .
  2. Re: big problem oil pump chain smashed thru alloy case
    May 2007
    knee deep in clunge
    14 Post(s)
    I will check it properly when I have time
  3. Re: big problem oil pump chain smashed thru alloy case
    Feb 2010
    staffordshire
    Pictures of a passat having the conversion done , gives you some idea of what's involved.
    http://pics.tdiclub.com/data/3419/BH...eplacement.pdf
    Full vcds HEX-USB-CAN Interface available in the staffordshire area PM me
  4. Re: big problem oil pump chain smashed thru alloy case
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by mauricedar View Post
    Sorry my mistake chain to gear
  5. Re: big problem oil pump chain smashed thru alloy case
    Feb 2010
    staffordshire
    Jon , out of interest how many conversions have you done, paid or warranty .
    The other audi forums have a few people with this problem.
    Thanks.
  6. Re: big problem oil pump chain smashed thru alloy case
    May 2007
    knee deep in clunge
    14 Post(s)
    I have never done one and only know of two in my workshop and I have been at my current shop for 8 years
    I only get dirty at the weekends lol
    Please accept my apology for incorrect information on the conversion
  7. Re: big problem oil pump chain smashed thru alloy case
    #17
    Aug 2009
    wales
    thats ok thanks for all your replys
    the car garage has phoned the warrenty company and it looks like they have got to send a guy out to check the work
    so im just waiting on that
    shall keep you updated
  8. Re: big problem oil pump chain smashed thru alloy case
    #18
    Nov 2010
    Wales
    Is this problem likely to affect any of the BRD engines - mine is a July 07 build date, just wondered if by then they had found the problem and affected a cure??
  9. Re: big problem oil pump chain smashed thru alloy case
    #19
    Nov 2010
    Chorley, Lancs
    Hello there,
    I have same engine in my 05 2.0 tdi Avant. Had serious engine rattle over xmas and thought the worst, i`m a time served mechanic and was sure the noise was coming from the bottom front end of the engine, i even had a stethoscope on the sump! I did some ringing round and found that Audi no longer sell the original parts fitted on that model engine. They modded the parts at the end of 05 I think to gear drive. The plastic 15 pence chain guide fails resulting in the failure....... The only problem labour wise doing the job is removing the gear from the crankshaft. The sump also has to be changed as the oil pump housing is different. Long story short my clutch had gone on the aircon pump - right at the bottom of engine - and the noise was transferring through. My local vw audi specialist was quoting £2000 to do the job with parts which I didnt think was bad. He had 2 BLB`S in with the same fault! See if this link works - tp://cgi.ebay.co.uk/VW-AUDI-2-0-TD...item45f78b52ec
    just to show you the plastic guide.
    Hope this is of use
    Dan
  10. Re: big problem oil pump chain smashed thru alloy case
    #20
    May 2010
    GLASGOW
    Check out this link and download the file, i think it's what you're after.
    http://rapidshare.com/#!download|499tg|196154252|BHW_Balance_Shaft_Modul e_Replacement.pdf|1410
