Thread: B7 Retrofit Bluetooth Mic not working!!
Results 1 to 8 of 8
  1. B7 Retrofit Bluetooth Mic not working!!
    Mar 2008
    Hi I have recently fitted a bluetooth kit from eBay that a few people have installed on the forum see this link
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=320621027611
    the kit contained the following
    This kit contains :1x 8P0 035 503 E - Bluetooth Antenne
    1x 8L1 862 373 A - Microphone
    1x 8P1 862 335 - Bluetooth Interface
    Retrofit cables, installation and CODING instructions
    All of the install went well and vagcom all configured well. phone paired with the system and I get asked for voice commands. I have a MFSW and concert 2 The issue is that I cannot give any commands I can recieve and hear calls all ok but they cannot hear me. I checked all the mic connections and all seem ok. So looks like the mic is ******* although it is a new component Is there a quick way to check this on Vagcom or any other way? I set upo the sensitivity to 0dB as this was standard. Any help appreciated. I have tried to talk to the seller but they are no good. I would not recommend them at all.
  2. Re: B7 Retrofit Bluetooth Mic not working!!
    Feb 2010
    staffordshire
    Mine did the same common fault, pull the Mic connector apart and turn is around simple as that .
    Full vcds HEX-USB-CAN Interface available in the staffordshire area PM me
  3. Re: B7 Retrofit Bluetooth Mic not working!!
    Mar 2008
    Hi thanks very much will try first thing tomorrow. I am not to sure if it was your post but did u buy one of these kits and had an issue with it?
  4. Re: B7 Retrofit Bluetooth Mic not working!!
    Feb 2010
    staffordshire
    Quote Originally Posted by Norfolk-Boy View Post
    Yes I have two of these kits , when first fitted had exactly the same issue as yours, the Mic leads are wired wrong into the connector, easy fix unplug it turn around (so the connector block is the wrong way ) but the wiring will be correct .
    I've heard of a few others with the same issue .
    HTH
  5. Re: B7 Retrofit Bluetooth Mic not working!!
    Jun 2010
    gosport UK
    mine was the same, very easy fix
  6. Re: B7 Retrofit Bluetooth Mic not working!!
    Feb 2010
    staffordshire
    Forgot to mention its on there site about this issue
    http://www.carsystems.pl/pages/pl/le...m-with-mic.php
    They show swapping the wires in the mic , but its easier to swap the connector .
  7. Re: B7 Retrofit Bluetooth Mic not working!!
    Mar 2008
    Hi All thanks very much works a treat now and yes swapped it at the plug.
  8. Re: B7 Retrofit Bluetooth Mic not working!!
    Feb 2010
    staffordshire
    Glad its sorted .
  1. Fiscon vs VW OEM C or D or Premium Bluetooth
    By eob in forum In Car Entertainment
    Last Post: 02-11-2009, 10:42 AM
  2. A3 Sportback - Bluetooth tetrofit
    By JonathanK in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 12-10-2009, 03:49 PM
  3. Premium Bluetooth Issues
    By Jambo1874 in forum Tiguan
    Last Post: 12-09-2009, 07:34 PM
  4. Please Help Volume Adjustment not working on Bluetooth phone
    By nm2003 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-06-2009, 09:40 AM
