Hi, I have a 2003 sharan tdi. My rear windscreen wiper water pipe has two splits in it, one where the pipe popped off in front near side foot well, the other where the pipe is presumed split somewhere in the rear near side light cluster as when I removeed service cover it was flooded. I have mopped up what I can and I want to disable the rear windscreen wiper / washer from operating as I cant get to the pipe in the rear light cluster. The fuse box under dash has a clear plastic cover. I dont know how to remove and the hand book does not tell you, just says remove it. I have searced on google and there was a thread that said push plastic tab to each side of cover and lift cover. I have looked again at the clear plastic cover. To either side of the cover is a white plastic type lever. This appears to be hinged on a metal pin. Am I supposed to pull these two on either side to remove the clear cover or will that make the whole fuse box fall out.
