Thread: Parking brake warning
  1. Parking brake warning
    Jan 2010
    Redditch
    Hello
    Can anyone help with the problem on the park brake on my 3C Passat.
    I recently had a tow bar and dedicated electrics fitted, soon after the park brake started to show faults. It still works fine, but puts up the amber warning most of the time. I have changed the switch, and done a battery reset with no effect.
    The place thart fitted the bar and electrics seem to think it is unrelated to the towbar, to be expected really.
    I have just got a chap at work to scan my car with VCDS, the results seem to be rather confusing to me. There are a number of faults that I wasn't expecting to see. Have the garage cocked up the coding on the car?
    Or is it really unrelated?
    Report below.
    onday,20,December,2010,11:13:03:26831
    VCDS Version: Release 10.6.2
    Data version: 20101123
    David Allton
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72 76
    VIN: WVWZZZ3CZ7EXXXXXX Mileage: 115360km/71681miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    69-Trailer -- Status: Sporadic communication error 1000
    76-Park Assist -- Status: Malfunction 0010
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 CE HW: 03G 906 018 CE
    Component: R4 2.0l PPD1.5 G 9707
    Revision: --H45--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 05311 000 08193
    VCID: 6ADFC14E3C03
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
    Part No SW: 3C0 614 109 HW: 3C0 614 109
    Component: ESP 440 C4 H018 0001
    Revision: H018 Serial number: 0775384298
    Coding: 0029986
    Shop #: WSC 05311 000 00000
    VCID: DBB1148A6359
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
    Component: Climatic PQ35 141 0909
    Revision: 00141027 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 7BF1F40A4399
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000007034401
    Coding: 00800F0700041A00470A00000F000000000859435C0001
    VCID: 6BD1C44A33F9
    Part No: 3C2 955 119 B
    Component: Wischer 190407 022 0601
    Coding: 00046997
    Shop #: WSC 05311
    3 Faults Found:
    01501 - Bulb for Blinkers; Rear Left (M6)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 238
    Mileage: 114963 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.20 V
    OFF
    ON
    OFF
    OFF
    OFF
    01505 - Bulb for Blinkers; Rear Right (M8)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 238
    Mileage: 114963 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    OFF
    Voltage: 12.20 V
    OFF
    ON
    OFF
    OFF
    OFF
    01517 - Control Module for Trailer/Towing Sensor (J345)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 239
    Mileage: 114963 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 14.15 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
    Component: 0C AIRBAG VW8 032 2522
    Revision: 12032000 Serial number: 003B1P8KU7ZB
    Coding: 0012355
    VCID: 306B1326DA5F
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
    Component: Lenksäulenmodul 006 0010
    Revision: 00006000 Serial number: 3C5953507AH
    Coding: 0000013
    VCID: 35652232253D
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 960 K HW: 3C0 920 960 K
    Component: KOMBIINSTRUMENT VD1 1614
    Revision: V0007000 Serial number: 00000000000000
    Coding: 0007405
    Shop #: WSC 00371 210 80409
    VCID: 2B51044AF379
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C075020224
    Coding: 3DFD9C04C21003
    VCID: 214DE66281B5
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 239
    Mileage: 114963 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:34:58
    00470 - Combination comfort Databus in Single Wire
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 199
    Mileage: 114963 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:44:52
    Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 397D2E020925
    Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1132
    Revision: 32008001 Serial number: 00000574078421
    Coding: 0000693
    VCID: 3B71340A0319
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.134 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 35652232253D
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 042 0472
    Coding: 01910A0001860E763004941570085FCE107CA0
    VCID: 397D2E020925
    Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H07 9001
    Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Component: Innenraumueberw.004 0611
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1132
    Revision: 32008001 Serial number: 00000603578416
    Coding: 0000692
    VCID: 3C7337160617
    Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
    Part No SW: 3C0 907 801 G HW: 3C0 907 801 G
    Component: EPB VD8HC005 013 0005
    Revision: 013
    Coding: 0000012
    Shop #: WSC 00371 210 91492
    VCID: 2647F57EE89B
    2 Faults Found:
    02443 - Control Head
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 249
    Time Indication: 0
    Freeze Frame:
    Voltage: 12.32 V
    Count: 40
    02844 - Lamp for Automatic Parking Function
    009 - Open or Short to Ground - MIL ON
    Freeze Frame:
    Fault Status: 11101001
    Fault Priority: 4
    Fault Frequency: 45
    Reset counter: 209
    Mileage: 114960 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:51:02
    Freeze Frame:
    Voltage: 12.01 V
    Count: 64
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 T
    Component: Radio GR0 020 0023
    Revision: 0002006S Serial number: VWZ2Z2G3512068
    Coding: 0040400
    Shop #: WSC 05314 000 00000
    VCID: 3779283A3F31
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
    Component: J388 TUER-SG HL 1118
    Revision: 11006001 Serial number: 00000001661119
    Coding: 0000144
    VCID: 3D753A121D0D
    Address 69: Trailer
    Cannot be reached
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
    Component: J389 TUER-SG HR 1118
    Revision: 11006001 Serial number: 00000001666736
    Coding: 0000144
    VCID: 3E773D1E100B
    Address 76: Park Assist Labels: 3C0-919-283.lbl
    Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
    Component: Parkhilfe 8-Kan 004 0013
    Revision: 00004000 Serial number: 90630712401320
    Coding: 0010014
    VCID: 295DFE42F985
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 239
    Mileage: 114963 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 14:37:21
  2. Re: Parking brake warning
    The park assist control modul is not coded for a trailer nor is the central electronics control unit
  3. Re: Parking brake warning
    Norfolk
    Quote Originally Posted by kenney View Post
    Are you sure Kenny. It loks to me like the modules are coded but none of them can communicate with the trailer module....faulty module or wiring ?
    If it was me I would clear the faults and rescan as these could be due to someone turning ignition on before they finished checking the new wiring.
    Is the brake faukt not just a failed bulb or bad connection to the autohold lamp. (assuming it has autohold).
  4. Re: Parking brake warning
    Coding: 00800F0700041A00470A00000F000000000859435C0001 central electronics
    byte 04 is coded no trailer and sorry the parking brake modul is coded correctly no communication could mean the units are not connecting through the gateway since the electronic control unit is not coded for a trailer
  5. Re: Parking brake warning
    Jan 2010
    Redditch
    Thanks for the quick responses guys.
    The faults have been cleared and re read
    The car does not have auto hold, but it appears to be coded for it.
    Is this what is upsetting the parking ECU?
    The lack of comms to the trailer ECU is a worry. Kenny seems to be correct about the central elect not being coded for trailer, the park assist I can't tell as Martin has no calculator for that unit
    Martin1810 your website is a thing of wonder, the coding spreadsheets are fantastic!
    Last edited by reynard55; 20-12-2010 at 03:51 PM. Reason: dont know my conv from elec ecu's
  6. Re: Parking brake warning
    the coding for Address 53: Parking Brake Labels should be 0000011,change it,activate bit2 in byte 04 in the central electronics and take it from there,i think that is why you have the fault with the indicators logged in the control unit
    Last edited by kenney; 20-12-2010 at 05:41 PM. Reason: forgot to mention coding of electronic control unit
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. DRLs, is this setup possible?
    By g-black in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2013, 08:37 AM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. Low Brake Pad Warning & Changing Lower Gear
    By dna_628 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-06-2007, 03:29 PM
