Thread: Belt Replacment
Results 1 to 8 of 8
  1. Belt Replacment
    Jun 2010
    Ireland
    There's quite a noticeable squeaking coming from the front of the car when the air con is on which I presume the belt is going. Is there a Gide anywhere for replacement also probably worth doing the aux belt as well as from what I know the whole bumper needs to come off. Is there anything else should be replaced or checked while the bumper is off.
  2. Re: Belt Replacment
    Quote Originally Posted by Peter_HMR View Post
    You dont say which engine you have, on TDI its cam belt replacement which requires the front to be pulled forward. If its just the aux drive belts you need to search for tensioner and alternator pulley problems before changing the belts.
    Jun 2010
    Ireland
    It's the 130bhp AWX diesel. The cam belt is fine it's the belt for the air con that needs to be replaced just wondering if anyone has a guide for it. Also what needs to be looked out for on the tensioner?
  4. Re: Belt Replacment
    May 2010
    Devon England
    the aircon belt you can replace very easy, take off the under tray, then with a 5 or 6 mm allen key undo the 2 or 3 bolts on the tensoner, move the tensoner out the way and the belt comes off, to refit put the belt on then with a 17mm spanner move the tensoner so the belt is tight enough and then tighten up the allen bolts job done mate
  5. Re: Belt Replacment
    Squealing from the front is usually the alternator pulley clutch seized and wrecking the tensioner, if you are sure it is the air con belt and the tension is adjusted correctly on this, it could be the compressor seizing up.
    Jun 2010
    Ireland
    It's only when the air con is on that the noise is there and if i put it into econ it goes off. If it's an easy job I'll just replace the belt but the front bumper is sitting a bit low so I was going to take off the front and replace both belts and just have a look to make sure everything is ok. Is there any way to narrow it down to the compressor?
  7. Re: Belt Replacment
    May 2010
    Devon England
    yes mate take the belt off and spin it to see if you can hear any noise
  8. Re: Belt Replacment
    Apr 2009
    Is there not a pulley-clutch on the AC compressor, that can chirp
    when its on its way out, and under load?
    Regards
    Jim
  1. Replies: 7
    Last Post: 12-05-2016, 01:50 AM
  2. Cam Belt damaged
    By awmw in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-12-2010, 08:54 PM
  3. Question Correct fitting position of alternator belt on 1.9 td
    By Camp-freddy in forum The Commercial Range
    Last Post: 15-01-2010, 03:00 PM
  4. Guide S4/A4 V6 Cambelt
    By spellmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 05:23 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
