Thread: Replaced Brake fluid (bled system). Red Brake warning light appears!
  1. Replaced Brake fluid (bled system). Red Brake warning light appears!
    Dec 2009
    Wanstead, London
    Hi there!
    As stated above, I have just replaced all the brake fluid in my car with new fluid and once i started the car the RED brake warning lights came on and didnt turn off. I've tried getting the cars ABS to kick in to perhaps fix it, and whilst it does kick in, the brake warning light doesen't turn off! this includes the handbrake warning light.
    Anything i've done wrong or need to do? I've disconnected the battery for now, hoping this might fix it but not sure.
    I bled all the old fluid from the calipers using a pressure bleeding machine (thanks to my college garage)
    and at the same time it was pressurising the brake fluid container with new fluid.
    Any comments welcome.
    Thanks in advance,
    Fahim.
  2. Re: Replaced Brake fluid (bled system). Red Brake warning light appears!
    Mar 2008
    High Wycombe
    Did you at any time run out of fluid in the pressure bleeder? This will let air into the master cylinder, which is bad.
    What pressure did you set the bleeder at? Different cars have different bleeding pressure requirements.
    Do the brakes work OK? Which brake warning symbol is it? Fluid level or brake pad wear?
    Last edited by NickPicks; 15-12-2010 at 10:06 PM. Reason: though of something else
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Replaced Brake fluid (bled system). Red Brake warning light appears!
    May 2010
    Devon England
    it could be the sensor has got a bit of dirt on it from the fluid change, im not 100% sure where the sensor is but if it can be removered i would try that first mate
  4. Re: Replaced Brake fluid (bled system). Red Brake warning light appears!
    Chester-le-Street, United Kingdom
    sounds to me as if you have disturbed one of the
    pad wear wiring connections on the callipers
    when you have been into the bleed screws,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
    Oct 2010
    Here And There
    Why dont you do a diagnostic scan incase the pressure has triggered some sort of fault that requires erasing
  6. Re: Replaced Brake fluid (bled system). Red Brake warning light appears!
    Dec 2009
    Wanstead, London
    Firstly I'd like to thank you all for your related input. Much appreciated to see the forum helping out a fellow member.
    STEWY L seems to be correct. I had my car taken in for a much due live data log feed by AMD Lakeside for poor mpg concerns and they said one of my brake wires near the caliper had broken i think so they've moved it for now but it will need replacing or soldering in the near future.
    Thanks a lot guys/girls.
  7. Re: Replaced Brake fluid (bled system). Red Brake warning light appears!
    thanks for the feed back, K.
    regards,
    stewy.
    4th cog,--two to go
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. Advanced new audi a6 travels light to tackle emissions
    Last Post: 11-12-2010, 07:22 PM
  3. All-new audi a8 travels light to miami debut
    Last Post: 02-12-2009, 08:58 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
