Thread: No spark
  1. No spark
    Oct 2010
    alto, usa
    I recently did a valve job on a 1990 Coupe quattro. It ran before but with the obvious lack of power. I reassembled the engine and installed it but now although it turns over, I have no visible spark . I'm out of ideas....thx
  2. Re: No spark
    1840 Post(s)
    You have put this in an odd place. What engine code is in the car?
  3. Re: No spark
    Oct 2010
    alto, usa
    I am new to this ....sorry. It is a 2.3 l 20v I believe it ias a 7A thanks
  4. Re: No spark
    1840 Post(s)
    It could be a crank position sensor fault but one I used to see a lot was the plastic gear on the base of the distributor breaking off. Make sure the rotor arm is going round and that the timing is correct. Have you checked for power to the coil?
  5. Re: No spark
    Oct 2010
    alto, usa
    How do I check the crank position sensor? I assume it consists of the two cylinders installed near the flywheel position hole. Is this correct? I don't have a manual which shows all of the components so I may be confused on this. I purchased a rebuilt (Bosch) Distributor since the old one had a crack in the drive gear. I did check for power to the coil and it was ok.....thanks
  6. Re: No spark
    1840 Post(s)
    You use an oscilloscope. One is the crank position sensor, the other the speed sensor.
  1. cranks but no spark, please help me!!
    By gloftimmingblet in forum Golf MK3 - 1993 - 1999
    Last Post: 26-03-2009, 09:15 PM
  2. VW passat v5 no spark
    By mariusmssj in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-05-2008, 04:43 PM
  3. lol! did just about everytyhing, and 94 2.0L Jetta STILL NO SPARK!
    By sinanovicha in forum Vento - 1994 - 1998
    Last Post: 13-12-2007, 08:33 PM
  4. Golf with no spark
    By spanner in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-03-2007, 10:04 PM
