Thread: Turbo Acuator Length adjustment on VNT TURBO on 1.9 Sharan
  1. Question Turbo Acuator Length adjustment on VNT TURBO on 1.9 Sharan
    Oct 2009
    Maidenhead England
    Hello
    i notice that the VNT turbo on the Sharan 1.9 2006 has an Actuator to control when the VNT nozzels Adjust .
    i also notice that there is a thread to adjust the length of the Actuator arm
    1. goes someone know how i can find the factory specification length for the Actuator rod length ?
    2.and if its too long and adjusted incorectly is it possible that the Vanes can make contact with the turbos thrust compressor wheel and damage it ?
    Regards
  2. Re: Turbo Acuator Length adjustment on VNT TURBO on 1.9 Sharan
    Push the charge pressure valve lever in the direction of the vacuum unit onto stop and hold in place.
    Then adjust the length of operating rod so that the eye of the rod can be placed over the pin of the lever with ease.
    Screw in the operating rod 8 turns (rod will be shortened).
    Tighten lock nuts.
    Connect then the operating rod onto the lever and secure with locking tab
  3. Thumbs up Re: Turbo Acuator Length adjustment on VNT TURBO on 1.9 Sharan
    Oct 2009
    Maidenhead England
    Quote Originally Posted by kenney View Post
    Tighten lock nuts.
    thanks for the information
    i guess it will make more sense when i look at it again as im unsure about some terminology
    i will understand what you mean when i see it
    thank you very much
  1. Binding brakes ??
    By mini mik in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2010, 09:54 PM
  2. Is this a Turbo? - 04 Passat 130 1.9 TDi
    By TeaTimeGilly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2008, 07:18 PM
  3. Blown Turbo on AFN 1.9TDi engine?
    By justbretta in forum Archive posts
    Last Post: 18-12-2007, 04:56 PM
  4. Passat 130Tdi turbo problems
    By Jon Tallis in forum Archive posts
    Last Post: 05-06-2007, 07:52 AM
  5. 1.9 tdi turbo cut out/ emission warning light
    By warwick01045 in forum Archive posts
    Last Post: 03-06-2007, 11:12 AM
