Thread: coolant temp sensor location
Results 1 to 9 of 9
  1. Question coolant temp sensor location
    Jan 2009
    Birmingham
    35 Post(s)
    any one got any pic of were the coolant temp sendor is located on a audi a4 1.9tdi 2004 cant seem to find the bloody thing
  2. Re: coolant temp sensor location
    1840 Post(s)
    Round the back of the head jammed between the head and the bulkhead and pointed towards the cars right inner wing.
  3. Re: coolant temp sensor location
    Sep 2007
    Windy Westcountry!
    Awkward to get to but simple enough to replace.
    Sensor is held in place with a circular plastic clip that slips over and locks into the metal housing around the temp sensor. There's also a rubber O ring inside.
    Don't forget to drain the coolant off a little as it'll all come flying out when you take out the sensor. And definitely dont' do what I did and mix the wrong coolant types. Bad idea.
    Not sure if you need this info but it's one of the few things I've recently replaced and thought it might help.
  4. Re: coolant temp sensor location
    Jan 2009
    Birmingham
    35 Post(s)
    Why what coolant did you put it I just bought a 1.5L of g12 plus plus from eBay I just top it up with that if needed
  5. Re: coolant temp sensor location
    Sep 2007
    Windy Westcountry!
    I used blue coolant (G11) which will creates an acidic solution when mixed with G12++. Sounds like you've got the right stuff.
  6. Re: coolant temp sensor location
    Liverpool
    11 Post(s)
    Sorry to jump in guys, how do you know what coolant you have in there, G11 or G12??? And should I only top up my 3.0 2003 with whats already in there?
  7. Re: coolant temp sensor location
    1840 Post(s)
    Use G12++ from a VAG dealer.
  8. Re: coolant temp sensor location
    Liverpool
    11 Post(s)
    cheers again Crasher, bought 1.5 litres of G12++ today (£8 ish), depending how much I lose when I replace the CTS, do I fill back up to 'max' with neat G12++?
  9. Re: coolant temp sensor location
    1840 Post(s)
    Mix some 50/50 with water and top up as necessary.
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  3. Question Coolant temp in matrix drops when i accelerate
    By irishpassats in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 04:22 PM
  4. Lupo temp coolant light + brown coolant
    By andyt67 in forum Polo - Derby - Lupo - Fox
    Last Post: 02-05-2009, 09:52 AM
  5. "How To" The FAQ & How To Thread
    By Ben in forum General
