Thread: Glowplug seized 2.5 tdi
Results 1 to 10 of 16
  1. Glowplug seized 2.5 tdi
    Having smokey and lumpy cold starts these cold mornings i decided to replace the glowplugs.
    Checked all the resistance and they are all around 130 ohms - bad.
    Set to it after a long drive so the engine was warm (read many people recomending doing it warm).
    First one i tried really tight, not using too much tourque undoing it, then it suddenly became very easy and just kept turning ...... Aghhh!
    Has anyone sucessfully removed a snapped glow plug using easy outs extractors and drilling?
    Don't know whether to carry on or give up. Started the engine and checked i still have compression, looks and sounds ok.
    Allroad 2.5 tdi BAU Tip
    A4 Avant 1.9 tdi (homebrew remap) sport
  2. Re: Glowplug seized 2.5 tdi
    Yes they have. Search the forum. Regards Peter
  3. Re: Glowplug seized 2.5 tdi
    thanks, ran many searches before posting, nothing with any solutions came up.
    Going to try the week of WD40 soaking then try again for the rest.
    Will see if the 1 out of 6 will be a problem after i've replaced the rest.
  4. Re: Glowplug seized 2.5 tdi
    WD40 is not the way forward. Plusgas is far better then with a removal tool then Loctite freeze release may be your saviour.
    Regards Peter
  5. Re: Glowplug seized 2.5 tdi
    Aug 2007
    Midlands, Uk.
    Quote Originally Posted by Peter D View Post
    Regards Peter
    Great tips, will get some of this and keep in the garage for future, never heard of them!
  6. Re: Glowplug seized 2.5 tdi
    Mar 2008
    High Wycombe
    Quote Originally Posted by Columbo View Post
    A quick search for "Glowplug snapped" came up with this thread which linked to this other thread which has some very useful advice from our resident experts Peter D and Crasher.
    This should help.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  7. Re: Glowplug seized 2.5 tdi
    Aug 2007
    Wicklow
    You don't really need the 6 anyway. VAG engines are renound for being able to start on very few plugs.
    If it comes out then happy days, if not then plug over it with liquid metal to seal it up and go with the 5.
  8. Re: Glowplug seized 2.5 tdi
    Regards Peter
    Yes Plus Gas is excellent, there are some people on Ebay selling it at a good price. I couldn't find it locally (although I didn't look that hard).
  9. Re: Glowplug seized 2.5 tdi
    Jun 2006
    UK, Mids
    What is snapping? I have six waiting for the weekend to fit.
    The threaded shank is the same part as the hexagon, so I can't see how this could snap, are the originals a different design or does it literally shear?
    Audi A8 - 2015 - 3.0TDI
  10. Re: Glowplug seized 2.5 tdi
    london/ UK
    The old plugs are made of an aluminised steel alloy and being dissimilar metals (the head and plugs) they will corode so the plug will just shear off. The new plugs are made off stainless steel wich is even softer than the old ones but they wont corode but that does not stops the head corodding around the plugs. Use plus gas as its the only good penetrating oil wich will work and make shure you spray them every day for a few days prior removal just to be on the safe side !
  1. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  2. Volkswagen launches new range of highly efficient golf models
    Last Post: 03-07-2009, 07:48 PM
  3. Replies: 0
  4. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  5. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
