Thread: Beetle 1.6SR rough idle and power loss
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
  1. Re: Beetle 1.6SR rough idle and power loss
    #31
    41 Post(s)
    922 Post(s)
    It is a cool way of showing long full code reads without it taking up huge amounts of thread space, I noticed it on the Ross Tech forum and then noticed it was on here. You use the # symbol in the menu above a advanced post reply (not shown in quick post) and the put the saved code read in between the code words in square brackets, is there an engine fault stored?
  2. Re: Beetle 1.6SR rough idle and power loss
    #32
    Sep 2019
    Stratford upon avon
    I clear that one code and that's all that comes up every time I scan. Do I need to do more than just clear it after the scan?
  3. Re: Beetle 1.6SR rough idle and power loss
    #33
    41 Post(s)
    922 Post(s)
    It is saying there is a code stored in the engine, if there isn’t it’s odd.
  4. Re: Beetle 1.6SR rough idle and power loss
    #34
    Sep 2019
    Stratford upon avon
    Is there a way to clear it other than scanning and clearing like I'm doing?
  5. Re: Beetle 1.6SR rough idle and power loss
    #35
    41 Post(s)
    922 Post(s)
    Try disconnecting the battery over night.
  6. Re: Beetle 1.6SR rough idle and power loss
    #36
    Sep 2019
    Stratford upon avon
    Will give it a go and get back to you. Cheers
  7. Re: Beetle 1.6SR rough idle and power loss
    #37
    Sep 2019
    Stratford upon avon
    Hi crasher, I've tried the battery and had it off for 10 hours and no joy.
    I now have an egr fault, lambda fault which I've already done and it's running too lean.
    Any ideas now. Cheers
  8. Re: Beetle 1.6SR rough idle and power loss
    #38
    Sep 2019
    Stratford upon avon
    Could it be a problem with the inlet manifold?
  9. Re: Beetle 1.6SR rough idle and power loss
    #39
    41 Post(s)
    922 Post(s)
    Where did these sudden engine codes come from? What are the code numbers?
    steve
  10. Re: Beetle 1.6SR rough idle and power loss
    #40
    Sep 2019
    Stratford upon avon
    No idea as I've not been using it. Will get the codes for you. Still have the dtc check memory one too
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Random Power Loss
    By jonathanfenton in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-02-2010, 08:58 AM
  3. Power loss problem SOLVED !!! A must read
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-05-2008, 02:26 PM
  4. erratic idle and loss of power
    By anya in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-02-2007, 10:16 PM
  5. Sick Golf GT 150 Pd TDi. Power loss, poor idle
    By lchris21 in forum Archive posts
    Last Post: 17-12-2006, 09:02 PM
