Thread: Battery Drain
Results 1 to 8 of 8
  1. Battery Drain
    Hi all
    Ive got battery drain , pinned it down to the stereo does anybody know that changing the stereo would cure the problem ??? or is there a underlying problem elsewhere ?
  2. Re: Battery Drain
    Norfolk
    What stereo. This is quite common with aftermarket stereos when the same feed is used for power and ignition feed.
  3. Re: Battery Drain
    It's the standard gamma stereo that's giving the problems
  4. Re: Battery Drain
    Quote Originally Posted by stirz36 View Post
    Hi all
    What sort of drain, is it enough to cause problems? or do you have a poor battery/charging problem and are looking for a reason?
  5. Re: Battery Drain
    With the stereo fuse in it's drawing 1.86 amps with it pulled out 0.8 amps other posts report common problem is the stereo but I need to know if replacing the stereo will cure the problem ?
  6. Re: Battery Drain
    Norfolk
    That's a massive current drain. The stereo must be faulty.
  7. Re: Battery Drain
    Jun 2006
    UK, Mids
    Before buying a new one, I'd pull it out and unplug it to be sure, in case there something on the same fuse or an accessory fitted behind the dash by a previous owner such as carphone kit or amplifier.
    Audi A8 - 2015 - 3.0TDI
  8. Re: Battery Drain
    Nothing else on that line had the car 8 years its standard , tried unPluging the cd Player no change deff the radio
  1. How To Remove battery without removing windscreen cowling & drain plenum, inc TDi
    By cazyp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-11-2014, 03:03 PM
  2. Please Help Battery Drain (Whilst Ignition Is OFF) - Data From My Tests Enclosed
    By EViS in forum Polo - Derby - Lupo - Fox
    Last Post: 13-09-2010, 06:54 PM
  3. Getting at the drain under the Passat battery
    By swampman in forum Volkswagen
    Last Post: 22-12-2009, 12:30 PM
  4. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  5. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
