Thread: Emission Control warning light
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Emission Control warning light
    Oct 2009
    Birtley
    I just got back from taking my eldest to nursery and noticed that my emission control warning light has come on. Does anyone know what might cause this?
    (The weather here has been horrendous and we have over a foot of snow. I reversed out of my drive and could have got snow in my exhausts if that is a possibility?)
    Allan
    Audi A4 2.0TDI Quattro 177PS Black Edition (B8.5) in Brilliant Black, B&O sound system, MMI 3G+ satnav, Parking System plus, Interior LEDs, Privacy Windows
  2. Re: Emission Control warning light
    Dec 2007
    could be a few things
    get the codes read and take it from there
  3. Re: Emission Control warning light
    Oct 2009
    Birtley
    Quote Originally Posted by bez101 View Post
    Do you think I should take it to the dealer to do that? Or get someone with the hardware to do it? Does anyone here have the hardware in the Newcastle/Durham area?
    Allan
  4. Re: Emission Control warning light
    The emissions control light is what used to be called the MIL or CEL. Whatever you call it it means there is a fault logged in the ECU that requires attention.
    I wouldn't take it to a main dealer to get it scanned, they will charge you £90, find a friendly local with VCDS or go to an independant garage. Most will only charge around £30. Make sure you get a print out of all the error codes.
  5. Re: Emission Control warning light
    Oct 2009
    Birtley
  6. Re: Emission Control warning light
    Yes providing they say it is compatable with your car. The Ebay leads can be troublesome but I have one and it works fine on my car.
    There is a free version of VCDS-Lite, or you can register it for £50. The registered version gives you access to all the fault code descriptions, allows you to do a full scan and allows you to turn off the light. If you get one do a scan and post the results on here and we will see what we can make of them
  7. Re: Emission Control warning light
    Oct 2009
    Birtley
    Quote Originally Posted by iwaters View Post
    Sorry, I think I edited my post whilst you were replying. I found a VCDS-lite (the ebay link) and another one based in China which is VCDS 10.6. What is the difference between the two?
    Allan
  8. Re: Emission Control warning light
    The one in China is a cloned copy of the full version of VCDS. It is a pirate copy. It probably wont work and may even knacker your car.
    Personally I would avoid it like the plague. Not least for the fact that Ross Tech (who make VCDS) already provide a free version of the software, and you can register it to unlock the other features for £50. Most other diagnostic software costs a hell of a lot more than this so it is worth supporting them and not buying clones.
    The other one is a generic cable that works with the cut down version of VCDS, which is called VCDS-Lite. This should be sufficient for your needs.
  9. Re: Emission Control warning light
    Oct 2009
    Birtley
    Thanks for the information. I have ordered the VCDS-Lite cable. Do you think I should be able to run my car until it arrives? I would only be doing short journeys and not on motorway.
    Allan
  10. Re: Emission Control warning light
    Quote Originally Posted by allanmb View Post
    Allan
    I wouldn't like to say really. It depends on what the fault codes are.
  1. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  2. Bentley announces detailed specification of new mulsanne
  3. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  4. Emission Control System Light Warning
    By OliSmi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-01-2008, 11:23 PM
  5. 1.9 tdi turbo cut out/ emission warning light
    By warwick01045 in forum Archive posts
    Last Post: 03-06-2007, 11:12 AM
