Thread: blowing fuse
  1. blowing fuse
    bolton lancs
    hi hoping someone can help a friend has a b6 2005 a4 estate 1.9tdi & last week it went in limp mode & the brake lights were on constantly when the ignition was switched on fitted new switch but didnt cure it.when i checked it i found a 15amp fuse in the ecu compartment blown so replaced with new fuse & all was working well again until today when its blown the same fuse but each time new one is fitted as soon as ignition is switched on the fuse blows instantly.does anyone know what this fuse supplies then i can investigate futher
    many thanks chris
  2. Re: blowing fuse
    Ireland
    Can you give us some details of the fuse, location & position, any number(s), maybe a picture with it highlighted?
    02 1.8T A4 B6 AVJ 150bhp (190map)
    02 1.6 Beetle AYD 101bhp
    VAGCOM 409.1-s
  3. Re: blowing fuse
    bolton lancs
    Quote Originally Posted by burkey1 View Post
    hi burkey inside the ecu compartment there is a maxi fuse 60amp this is for the glow plugs, then there is a 15amp in a red holder & a 15 amp in a blue holder this blue one being the culprit.I have been to it today & it has stopped blowing the fuse but for how long who knows.
    chris
  4. Re: blowing fuse
    Ireland
    Im going to need your engine code, three letters should be in the manual/service book.
    Also is it an 8E5 or a 8ED avant.
    VAGCOM 409.1-s
  1. Instrument cluster fuse Keeps blowing
    By mm#2 in forum 80 - 90
    Last Post: 06-05-2009, 11:30 PM
  2. 1996 Polo blowing fuse 21 (interior lights and locking)
    By GavHT in forum Polo - Derby - Lupo - Fox
    Last Post: 24-11-2007, 04:46 AM
  3. A4 95/96 Engine Management Fuse blowing
    By PClements in forum Archive posts
    Last Post: 01-11-2007, 09:46 PM
  4. ECM Fuse blowing
    By mikespain in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 01:08 PM
  5. BORA fuses blowing ? Which fuse how many Ampere ?
    By henri in forum Bora - 1998 - 2005
    Last Post: 22-02-2006, 11:23 PM
