Thread: 1.4TSI engine noisey on start up
Results 1 to 10 of 15
  1. 1.4TSI engine noisey on start up
    Nov 2010
    bristol
    When I start the engine on cold mornings it makes a lot of noise for a few seconds. This is worrying me, as I've only experienced this once before and that was with a 10 year old worn out engine in a Mazda.
    Is this a problem with my car or does the 1.4TSI engine suffer this problem?
    Also, should I take it back to the dealer for them to investigate?
  2. Re: 1.4TSI engine noisey on start up
    Jun 2011
    glasgow
    Hi i have the same exact problem with my Audi a3 1.4 tsfi, did you get anywhere with finding what the problem was?
    Many Thanks
    Fraser
  3. Re: 1.4TSI engine noisey on start up
    May 2007
    knee deep in clunge
    14 Post(s)
    its a brief build up of fuel pressure and causes no issue however it does give the impression the engine has a mechanical fault, no repair is advised as this is a knock on effect of the delivery pressure from initial cold start or
    Brief malfunction of the camshaft positioner, if this is the case then the postioner requires replacement
  4. Re: 1.4TSI engine noisey on start up
    Jun 2011
    glasgow
    Hi many thanks for your reply, my local audi dealer after many times in with the problem eventually faulted the problem as the fuel pressure but with no fix. I had the car at an independent and they immediately faulted the noise as a possible camshaft retentioner or oil valve problem and advised to take it back to audi as it is an expensive repair and should be covered by goodwill. The car went back to audi another twice and they have now faulted the problem as the camshaft positioner and are replacing the camshaft positioner. Would the malfunction of the camshaft postioner damage anything in the engine and should they be replacing any other parts?
    many thanks
    Fraser
  5. Re: 1.4TSI engine noisey on start up
    May 2007
    knee deep in clunge
    14 Post(s)
    If it is in fact the camshaft postioner then there are modified parts for the exact repair and no consequential damage occurs, however if the fault re occurs then its as described in post 3 with no repair required
    good luck and report back with your results
  6. Re: 1.4TSI engine noisey on start up
    Jun 2011
    glasgow
    Hi A8 tech i had the work done and everything seems ok, i still sometimes get my engine over revving at start up by 400-600 rpm which I'm guessing is the possible build up from fuel pressure but i don't have the rough sounding metallic start up that i did have previously? The fuel pressure over revving seems to happen when the car has been lying out all day noticeably when it has been warm. It seems like the Sirrocco has a similar problem, you can listen to the sound of the engine stating up on youtube.
  7. Re: 1.4TSI engine noisey on start up
    Nov 2010
    bristol
    Hi A8 tech
    My Scirocco has been back to the VW dealer 3 times and on the last ocassion they changed the Camshaft Adjuster, but I still have the noise on start-up. I'm taking the car back again and will mention the Camshaft Positioner as a potential fault. I've also heard that the Camshaft Adjuster Soleniod Valve can stick and cause the noise. Have you heard this?
  8. Re: 1.4TSI engine noisey on start up
    May 2007
    knee deep in clunge
    14 Post(s)
    does it sound like this https://www.rapidshare.com/files/2543478548/000208.wma
    if yes you need the chain tensioner as well as the previous camshaft adjuster solenoid, the tensioner loses pressure hence there is slack in the chain from starting
  9. Re: 1.4TSI engine noisey on start up
    Nov 2010
    bristol
    the noise I get is not as load as this. It's a similar noise but not as load
  10. Re: 1.4TSI engine noisey on start up
    May 2014
    Helsinki, Finland
    Hi!
    Im having similar problems with my 2010 1.4tsi (92kw) seat leon, engine code CAXC. Every morning i start it, it sounds like this.
    1.4 TSI Start noise. - YouTube
    WSLAWSON, did your car sound similar to mine? And did replacing the camshaft positioner solved the problem? And A8 tech, could falty camshaft positioner cause this noise???
    Thanks!
    Jouni
  1. Replies: 16
    Last Post: 24-11-2016, 01:28 PM
  2. t4 1.9td wont start after replacing engine
    By azim in forum The Classic VW's
    Last Post: 24-08-2010, 08:09 PM
  3. Engine start and stop now works only for 1 minute?
    By fab1975 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-07-2010, 10:35 AM
  4. oil warning signal
    By ger83 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 07:20 PM
  5. Question Engine problem - Engine speed sticks high / Unstable engine speed
    By sef-75 in forum Bora - 1998 - 2005
    Last Post: 29-09-2009, 09:52 PM
