Thread: Coolant warning light
  1. Coolant warning light
    Oct 2009
    Stirlingshire
    I've had a intermitant temp gauge so I changed the water temp sender on my '02 1.8T Passat and after replacing the coolant that escaped during the process I now have the red warning light "Check coolant"in the dash light up and it won't go out even though the level is fine.I contacted the local VW dealer and they said that this was normal until the system bleeds itself but the light and warning buzzer are still on even after 3 days use.By the way the temperature gauge is still not working so it couldn't have been the sender - any ideas?
  2. Re: Coolant warning light
    What exactly is the guage doing. What coolant did you top up with and is the cennector to the header tank secure. Regards Peter
  3. Re: Coolant warning light
    Jun 2006
    UK, Mids
    With two faults, maybe a faulty instrument cluster?
    If the coolant in the reservoir is above MIN, the light should go off. you could try banging the reservoir in case the sender is jammed at the bottom of it's travel.
    Audi A8 - 2015 - 3.0TDI
  4. Re: Coolant warning light
    Oct 2009
    Stirlingshire
    Thanks for the quick replys.The gauge only works sometimes,it will go to 90 then fall back to zero,other times it will just barely move then return to zero.I didn't realise that there is a sender in the header tank itself,I'll check in the daylight.
  1. Engine Warning and EPC Light comes on periodically
    By d_kiy in forum Golf MK5 - 2004 - 2009
    Last Post: 21-05-2010, 10:45 AM
  2. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  3. Lupo temp coolant light + brown coolant
    By andyt67 in forum Polo - Derby - Lupo - Fox
    Last Post: 02-05-2009, 09:52 AM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Engine Warning Light 2001 Passat
    By derekdublin in forum Passat - Archive Topics
    Last Post: 09-02-2007, 08:10 PM
