Thread: Cabin Filter Seal - Is it visable with filter removed?
Results 1 to 8 of 8
  1. Cabin Filter Seal - Is it visable with filter removed?
    Oct 2009
    Worthing
    Right I've got soggy footwell disease as I live in a rather windy part of the world it has decided to rear it's ugly head.
    As soon as I got the car I sorted the plenum drains out and had a look at the cabin filter, but it was difficult to remove and I'm lazy so I didnt persever..... oh how silly of me...
    anyway... my question is:
    With the cabin filter removed, should I be able to see a seal in the little gap under the filter? Because...... I cant Maybe I have no seal....? (that'll be the problem then...)
    Do I need to buy a new one or can I just go silicon crazy and not remove the filter housing?
    I think I'll need to remove the scuttle pannel to get at the nuts for the filter housing as they were hand shreddlingly difficult to remove but I dont want to do this and find out that because I've got no seal or it is very very damaged that I'll need to put it all back together and order a new part.
    JAmes.
  2. Re: Cabin Filter Seal - Is it visable with filter removed?
    Jun 2006
    UK, Mids
    No, it's under the filter housing
    Audi A8 - 2015 - 3.0TDI
  3. Re: Cabin Filter Seal - Is it visable with filter removed?
    Oct 2009
    Worthing
    Hmm.. i guess I should order up a new one then before taking it all off
  4. Re: Cabin Filter Seal - Is it visable with filter removed?
    Jul 2010
    Brighton
    you sure it's not coming in via the door panels? VW's are terrible swimming pools
  5. Re: Cabin Filter Seal - Is it visable with filter removed?
    Oct 2009
    Worthing
    Hmm... it could be. I'll try to dry the car out and make sure all the seals are on OK around the door. I have noticed some water sitting on the sill pannel but never any over the rubber and into the cabin. Perhaps I should do some invstigating with a hose pipe....
  6. Re: Cabin Filter Seal - Is it visable with filter removed?
    Oct 2006
    Persevere and get the pollen filter housing out, my seal was completely knackered beneath the tray. I used a thich gutter sealant mastic. No problems since...touching wood!!!...Also removed the plenum drain rubbers.
  7. Re: Cabin Filter Seal - Is it visable with filter removed?
    Oct 2009
    Worthing
    Did you use a seal and mastic or just mastic?
  8. Re: Cabin Filter Seal - Is it visable with filter removed?
    Oct 2006
    Just the thick black gooey mastic.
  1. "How To" Passat B5.5 TDI Servicing
    By Col in forum Volkswagen
    Last Post: 02-05-2015, 04:11 AM
  2. Replacing crankcase breather on 2.5 V6 TDI - photos and description
    By SiliconS in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-11-2013, 03:41 PM
  3. Oil Change Results
    By DSG4ME in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-08-2010, 12:37 AM
  4. Replies: 0
    Last Post: 10-02-2010, 01:39 PM
  5. Don't Bother Changing the Factory Filter.....
    By mr X in forum Chat - Anything with wheels
    Last Post: 16-10-2009, 04:55 AM
