Thread: Just bought VCDS and need some help with Passat FSi codes
  1. Just bought VCDS and need some help with Passat FSi codes
    Aug 2007
    I have just bought a VCDS to look at a problem have with my Passat FSi.
    Although I am not new to diagnostics, I am new to this car and Can bus dignostics.
    My engine is failing to hold steady revs at idle and the VCDS reports 9 faults - Pasted below. I am guessing that it is possible for one problem to cause several fault codes to be recorded, so given the information and the faults codes what would you guys think would be the best place to start?
    Thanks in advance for any help.
    Nigel
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 3C0 907 115 Q HW: 3C0 907 115
    Component: 2.0l R4/4V TFSI 0030
    Revision: --H10--- Serial number: VWZCZ000000000
    Coding: 040C000318070160
    Shop #: WSC 00339 210 94680
    VCID: 2E59FF57C065
    9 Faults Found:
    012599 - Intake Manifold Runner Control: Basic Setting not Completed
    P3137 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 88773 km
    Time Indication: 0
    Freeze Frame:
    RPM: 195 /min
    Load: 52.9 %
    Speed: 0.0 km/h
    Temperature: 72.0°C
    Temperature: 57.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 10.668 V
    001602 - Sensor Reference Voltage A: Circuit: Low
    P0642 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 88773 km
    Time Indication: 0
    Freeze Frame:
    RPM: 195 /min
    Load: 52.9 %
    Speed: 0.0 km/h
    Temperature: 72.0°C
    Temperature: 57.0°C
    Voltage: 10.668 V
    012403 - Fuel Pump Circuit: Electrical Malfunction
    P3073 - 004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 89288 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:54:06
    Freeze Frame:
    RPM: 972 /min
    Load: 28.2 %
    Speed: 0.0 km/h
    Temperature: 4.0°C
    Temperature: 3.0°C
    Voltage: 14.478 V
    004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 89542 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:25:06
    Freeze Frame:
    RPM: 1508 /min
    Load: 20.8 %
    Speed: 41.0 km/h
    Temperature: 82.0°C
    Temperature: 16.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.478 V
    004243 - Bank 1; Fuel Measuring System 2: Malfunction
    P1093 - 008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 89548 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:32:30
    Freeze Frame:
    RPM: 1619 /min
    Load: 11.8 %
    Speed: 23.0 km/h
    Temperature: 84.0°C
    Temperature: 17.0°C
    Voltage: 14.351 V
    008583 - Bank 1; System too Lean at Idle
    P2187 - 004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 89560 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 09:00:50
    Freeze Frame:
    RPM: 817 /min
    Load: 15.7 %
    Speed: 1.0 km/h
    Temperature: 81.0°C
    Temperature: 13.0°C
    Absolute Pres.: 1020.0 mbar
    Voltage: 14.351 V
    008825 - Leak in Air Intake System
    P2279 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 89564 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:17:26
    Freeze Frame:
    RPM: 834 /min
    Load: 16.1 %
    Speed: 0.0 km/h
    Temperature: 81.0°C
    Temperature: 19.0°C
    Voltage: 14.478 V
    001287 - Idle Control System RPM: Higher than Expected.
    P0507 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 89635 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:34:25
    Freeze Frame:
    RPM: 1075 /min
    Load: 14.9 %
    Speed: 0.0 km/h
    Temperature: 84.0°C
    Temperature: 21.0°C
    Voltage: 14.351 V
    001089 - EVAP Emission Control Sys: Incorrect Flow
    P0441 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 89666 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:12:52
    Freeze Frame:
    RPM: 839 /min
    Load: 16.1 %
    Speed: 0.0 km/h
    Temperature: 85.0°C
    Temperature: 24.0°C
    Voltage: 14.097 V
    Readiness: 0000 0000
    Oct 2010
    Here And There
    If you do a search on my name and check my latest thread on MIL Problems, you might find the solution to a couple of your codes. The valve also makes an uneven idle that is shown from A8
  3. Re: Just bought VCDS and need some help with Passat FSi codes
    Sep 2009
    Apollo
    I haven't searched Bangor Lad's posts, but I agree that those problems / faults are common. In the US, several of the root causes are covered under recalls.
    I would focus on these 3:
    http://wiki.ross-tech.com/wiki/index...9/P2187/008583
    Either pull the oil cap at idle and see if vacuum is present inside the crankcase
    -or-
    With the engine Off, remove the black plastic hose/tube that goes to the breather valve and cap it off directly at the manifold. Make sure you choose a cap that will not get sucked into the engine! This will eliminate the possibility that the faulty valve can cause an internal leak. Start it and see if the idle has improved. You may also find this MB 032 info helpful both before and after clearing faults and bypassing the valve:
    http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info
    http://wiki.ross-tech.com/wiki/index...1/P2279/008825
    http://wiki.ross-tech.com/wiki/index...1/P0507/001287
  4. Re: Just bought VCDS and need some help with Passat FSi codes
    Aug 2007
    Ok, only today have i had chance to have a look at this problem, thank you for the replies.
    Even today I only managed to grab five minutes under the bonnet.
    So tried the simplest thing first, with the engine running I removed the oil filler cap and placed my hand over it and could feel a vacuum there. Is that what I should feel or is that a bad thing?
    Nigel
  5. Re: Just bought VCDS and need some help with Passat FSi codes
    Oct 2010
    Here And There
    Im not sure if thats the way it should be or not but mine does the same, did she start to run off cylinders and bad idle when you removed the oil cap ? Mine does this and thats after replacing the PCV although she now idles perfectly so I assume YES is the answer.
