Thread: Passat Gear Lever Rattle
  1. Question Passat Gear Lever Rattle
    Mar 2006
    I have just purchased 130 TDi Highline Estate, and have a rather annoying rattle coming from the gear lever under acceleration.
    Just wondering whether anyone has had or heard of how to cure the problem?
    Percy
    Mar 2006
    Whitehaven, Cumbria
    Percy,
    I haven’t had this problem but one thing I would check is the metal clip that holds the gear lever on. Remove the gaiter, the back comes out first, list the gaiter up as high as it will go and you will see a metal clip. Use a pair of pliers to make sure that this is tight. This might clear the problem.
    Chilly
    Mar 2006
    Cheers Chilly
    Mar 2006
    Did you manage to cure this fault? I have the same problem with my 2002 passat estate.
  5. New Gear Knob required
    Oct 2006
    Hi have cured this problem with a new gear lever, only trouble is it isn't cheap... Knob vibrates under acceleration and is very irritating...
    Only other thing I could suggest is lift up gear lever gaitor & replace clip if you can get one??
    Good-luck Golfer7
  1. Replace Passat Gear Lever Gaiter 52 Reg
    By PeterGittings in forum Passat - Archive Topics
    Last Post: 21-06-2007, 05:35 PM
  2. passat gear lever gator..
    By bigb1970 in forum Passat - Archive Topics
    Last Post: 23-01-2007, 04:01 PM
  3. Gear lever surround
    By Technical in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2007, 09:33 PM
  4. Passat Gear Lever
    By Westfieldmatt in forum Passat - Archive Topics
    Last Post: 20-11-2006, 03:05 PM
  5. passat 130pd gear lever buzzes
    By c12weddi16 in forum Passat - Archive Topics
    Last Post: 08-10-2006, 11:10 PM
