Thread: Steering Assist Basic Setting/Adaptation
  1. Steering Assist Basic Setting/Adaptation
    Nov 2010
    Llandrindod Wells Wales
    I am unable to sucessfully complete the above action. I am following the process listed in the ross-tech Wiki. Though, via VCDS I see displayed that the basic setting is 'done', I continue to have code 00778. During the steering limit stop adaptation, the column will rotate about 45 degrees to the right when the engine is switched off!
    I have been searching here, and will continue to do so, but, if anybody has had a similar experience, please .....
    I would like to understand what "end impact" is, it always reads "-44.8", is this why the column rotates?
    This has come about after disconnecting the battery!
    This is an early 5P model, registered in Dec 2004.
  2. Re: Steering Assist Basic Setting/Adaptation
    Nov 2010
    It would appear that the combination of having a 'pre-existing' ABS system fault code and disconnecting the battery led to the situation of the steering-assist not 'allowing' its 'resetting' procedure to 'run'.
    We fitted a new rear hub yesterday to sort the ABS ( sensor ring had corroded and 'crumbled'), steering 'came back to life' during a 'three-point turn' after doing the adaptations ( basic and limit stop ) !
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. How To DIS AND CRUISE RETRO FIT b6+b7
  3. How To retro fit cruise
    By a8 tech in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 07-03-2010, 01:34 PM
  4. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  5. mot
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2007, 06:20 PM
