Thread: Radio FM reception failing - lose connection
Results 1 to 10 of 12
  1. Radio FM reception failing - lose connection
    May 2007
    Hornchurch, Essex
    As of today my radio recption keeps failing. I will drive along with a stations frequency on with no music then it will just suddenly come on, then off again after a while. A firm shut of the boot brought it back on on one occassion and on 2 occassions giving the roof a whack near the rear window brought it back on.
    Unfortunately it does not stay on for long
    Seems to be a lose connection somewhere, any ideas?
    AUDI A4 1.8T QUATTRO SPORTS : 2001 B6
  2. Re: Radio FM reception failing - lose connection
    Southern County Softy
    20 Post(s)
    Saloon, Cab or Avant ?
    The antenna amp is known to fail.
    In the saloon it is above the rear window.
    In the cab the loom tends to break near the boot hinge.
    A4 2.5 tdi QS (mapped)
  3. Re: Radio FM reception failing - lose connection
    May 2007
    Hornchurch, Essex
    Quote Originally Posted by kite View Post
    Saloon. Above the rear window you say, i take it on the inside? how do i remove that section of the roof to get to it? any idea?
    thanks
  4. Re: Radio FM reception failing - lose connection
    20 Post(s)
    Above the window is a piece of trim that goes right across, take that off, it just pulls.
    The amp in above the nearside.
  5. Re: Radio FM reception failing - lose connection
    May 2007
    Hornchurch, Essex
    thanks, expensiive bit of kit that so i'm lead to believe. Founf the part number in another thread £140!! jesus!
  6. Re: Radio FM reception failing - lose connection
    20 Post(s)
    expensive and a regular failing part.........
  7. Re: Radio FM reception failing - lose connection
    May 2007
    Hornchurch, Essex
    Just took that panel off, that was a job on its own! one of the metal tags stayed in the roof instead of coming out with the panel, doubt i'll be able to get that out so no doubt it will never sit right again also where i was pulling it the material has come away from the plastic... time for some copydex!!
    I'm one of those blokes that tries to fix something and always ends up making it worse and ballsing up something else along the way with it lol
    Anyway, fiddling around with that part makes it come on and off, i twisted it in a position that is keeping it on for now.
    So what fails on the part?, sounds like just a duff connection to me
  8. Re: Radio FM reception failing - lose connection
    May 2007
    Hornchurch, Essex
    oh god, just been reading on other forums that i mioght have to replace the rear screen also?? that correct for my model?
  9. Re: Radio FM reception failing - lose connection
    Dec 2008
    as strange as it sounds you have'nt had HID lights installed recently have you. I have read somewhere that someone who had upgraded to HID was experiencing similar problems....
  10. Re: Radio FM reception failing - lose connection
    Nov 2008
    N/A
    If you do need an aerial amplifier, search ebay, there's loads.
  1. Radio Reception problem
    By NickPicks in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-06-2010, 11:30 AM
  2. Integral Bluetooth radio for A4
    By Gary M in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2010, 03:45 PM
  3. Please Help Poor radio reception when my A4 is moving
    By Jimmyboy11 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-09-2009, 11:23 AM
  4. 1997 VW Polo radio reception problem
    By wallsballs in forum Polo - Derby - Lupo - Fox
    Last Post: 14-01-2008, 01:26 AM
  5. Poor radio reception
    By peterc57 in forum Audi A4 - Archive Topics
    Last Post: 20-01-2007, 11:30 AM
