Thread: 5th GEAR WHINE
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. Re: 5th GEAR WHINE
    #21
    May 2015
    battle
    Quote Originally Posted by Montis Calpe View Post
    My car has just started doing this, only whilst releasing the clutch pedal whilst changing into 5th gear. Noise sound similar to driving over the white rumble strips at the edge of a motorway/ dual carriageway and lats a microsecond. If you dip and release the clutch the noise presents itself again. THIS ONLY HAPPENS IN 5TH GEAR. Anyone discovered a fix?
    I would be interested in this old thread, i have just bought a golf with the same. Any new news on this?
  2. Re: 5th GEAR WHINE
    #22
    Jul 2007
    glasgow
    35 Post(s)
    you could look up youtube and how to align a vw gearbox cable
    When you take off the plastic lugs on the cables, you may have to gently prise them off the threaded cable, clean with wire brush a grease up before adjusting
    It might be a cheap fix and better than taking your gearbox out
  3. Re: 5th GEAR WHINE
    #23
    Sep 2017
    leicester
    hi guys im new on here got a issue with my vw sharan 2005 1.9 tdi sport 115 happens on 5th gear when relising acceleration its winning quicker i speed and relise the accelerator the louder it is any idea what could it be i have read some adverts on here aswell as googled it said with driveshafts i replaced bothsides inch cv joint not got a clue what ment to do anymore been to mechanic and they think its the gearbox it has had new clutch fkywheel fitted by previous owner at 101k car has now just bellow 125k any advice is apririciated thank you
  4. Re: 5th GEAR WHINE
    #24
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Wrong section - this is B6 Passats.
    Mad Mitch
  5. Re: 5th GEAR WHINE
    #25
    Sep 2017
    leicester
    Quote Originally Posted by DMitch16 View Post
    sorry how do i post or open a new post for an quaery am.new and im.looking for any one who has had same issue and have resolved it
  6. Re: 5th GEAR WHINE
    #26
    Jan 2012
    10 Post(s)
    87 Post(s)
    Go back up the forum "tree" links to Volkswagen and then into the Touran - Sharan - Caravanelle section link. Open a New Thread when you are there. Alternatively a moderator may move your original post from the B6 Passat section to the correct forum section.
    Mad Mitch
  7. Re: 5th GEAR WHINE
    #27
    Sep 2017
    leicester
    thanks i will check theough mechanic and see if he can do it as i havent got any sort of tools to do it is there anything to take off before cleaning it or
  8. Re: 5th GEAR WHINE
    #28
    Jul 2007
    glasgow
    35 Post(s)
    change the oil and go to VW Parts Dept to get the right oil specs
    could also look at youtube in how to realign the gearbox rods for changing gear
  9. Re: 5th GEAR WHINE
    #29
    Sep 2017
    leicester
    i have been to a mechanic and he thinks its not the case of the cable to adjust as it doesnt crunch it goes smothly into all gears and nothing is stiff they said it could most likely sybcroniser or the presure plate bearing but they not 100% ssure
  10. Re: 5th GEAR WHINE
    #30
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    You said in your post #23 the noise is worst when you lift off the accelerator, ie. on the overrun in 5th gear, this is unlikely to be the clutch release 'pressure plate' bearing or syncro hub. You probably have a worn shaft bearing in the gearbox, you could try changing the oil and using an additive which might quieten it a bit, but long term it looks like a replacement box or overhaul.
  1. 04 GT TDI 140 whine in 5th gear
    By Toledo_Dave in forum Golf MK5 - 2004 - 2009
    Last Post: 08-12-2019, 12:51 AM
  2. Whining noise in 5th gear only
    By gordongecko in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-01-2010, 04:58 PM
  3. Please Help 1.4 ABD'd Golf gearbox - 5th gear gone
    By unkleGsif in forum Golf MK3 - 1993 - 1999
    Last Post: 07-11-2009, 07:23 PM
  4. 5th gear crunch leon 110 tdi
    By seatcol in forum Leon
    Last Post: 21-03-2008, 02:35 PM
