Thread: advice on buying VCDS/VCDS-lite
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
  1. Re: advice on buying VCDS/VCDS-lite
    #21
    Jul 2010
    Peterborough
    Well I've done it bought myself a xmas prezzie the VCDS. I'm not techie or mechanical minded so I hope I don't mess up using it!!!!!!!!!!!!!!!!!!!
    Oct 2010
    Here And There
    Quote Originally Posted by skidmarks View Post
    Just dont go changing things. It tells you what is safe and what you need to be carefull with. As long as you write things down, you can always change it back. If you have any questions, be sure to ask as everyone is a student when it comes to diagnostics no matter how long they have been doing it !!!
    Sent from my iPhone using Tapatalk and loving every minute of it !!!!
  3. Re: advice on buying VCDS/VCDS-lite
    #23
    Jul 2010
    Peterborough
    Thanks Bangor Lad. Good advice.
    Oct 2010
    Here And There
    Your very welcome
  5. Re: advice on buying VCDS/VCDS-lite
    #25
    Norfolk
    There are some .xls coding files that you can download from my site. These allow you to make changes as if you were using VCDS to see what some changes to coding should do.
  6. Re: advice on buying VCDS/VCDS-lite
    #26
    Jul 2010
    Peterborough
    Confused..........I will be using vcds but don't understand what your saying. Are these files applicable to Audi? Sorry but new to this.
  7. Re: advice on buying VCDS/VCDS-lite
    #27
    Norfolk
    Yes and No. The files on my site are for the B6 passat. They are based on the label files for the B6 passat.
    When you run a VCDS autoscan on your car you should see a line saying label file. That is the file for your car.
    So the options, changes etc that are available for your car will be on the screen according to that label file.
    If you plug your VCDS into a B6 passat you will get the B6 label file options which are the ones on my site.
    Using the .xls files on my site means you can see what changes actually do and how a shift in one 0 or zero can have a larger effect than you might expect.
    People are always getting things wrong with VCDS, partly through ignorance and partly because VAG make changes to hardware and software that we don't know about until we stumble across them. So a coding may work for a car built one month but not work for a car built one month later because a controller has been changed.
    Never assume all changes are reversible. Some are not and must not be attempted. Best to ask on a forum before making changes.
  8. Re: advice on buying VCDS/VCDS-lite
    #28
    Oct 2005
    Massive thanks to everyone who has posted in this thread.
    There was a time when everyone would recommend a pirated copy and a cheap ebay lead.
    We've not got members self policing and recommending the "proper-job" VCDS bundles.
    That makes me so proud - thank you
  9. Re: advice on buying VCDS/VCDS-lite
    #29
    Jul 2010
    Peterborough
    My first job when the vcds arrives will be to re-set the service indicator as I had the service done at my friendly local indy. Is that straight forward to do. Hopefully a nice easy one to start with!
  10. Re: advice on buying VCDS/VCDS-lite
    #30
    Norfolk
    There is a button on the first screen for Servic Reset Interval (SRI). You just pick the one you want. Remember the reset may not show on the cars service display for several hundred miles, depends on model.
  1. Question S3 - Sensible Buying Advice
    By esh in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-07-2010, 10:50 AM
  2. Buying advice s6 2.2
    By clive30v in forum 100 - 200 - Turbo - 100 S4
    Last Post: 06-10-2009, 02:17 PM
  3. Question Buying advice, petrol or diesel?
    By adburns in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2009, 09:12 AM
  4. Buying advice
    By chalkmyster in forum The Commercial Range
    Last Post: 20-06-2009, 06:32 PM
  5. Mk 3 Golf Buying Advice
    By NickPicks in forum Golf MK3 - 1993 - 1999
    Last Post: 09-06-2009, 09:35 PM
