Thread: Heater Blower Motor / resistor
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Heater Blower Motor / resistor
    Nov 2008
    Quote Originally Posted by Axios View Post
    I got some pictures of this if it will help any one out in the future.
    It would be great if you could send me some pics as my heater motor has just stopped working. My email address is j.maclean2@sky.com
    I will be really grateful if you can do this for me.
    Thanks again.
  2. Re: Heater Blower Motor / resistor
    Feb 2010
    Plymouth
    Quote Originally Posted by macscunge View Post
    Thanks again.
    I'll see what i can do when i get home mate.
    Have a look through the audi or parts section of my photobucket account.
    I think they are in there some where.
    Its in here some wher.
  3. Re: Heater Blower Motor / resistor
    Feb 2010
    Plymouth
    Little bit longer that i thought but i've found some spare time.
    here are some images i got of the heater motor.
  4. Re: Heater Blower Motor / resistor
    Nov 2008
    Thanks very much for your help
  5. Re: Heater Blower Motor / resistor
    Jan 2011
    bedford
    Hi, I have just got a 2003 VW Sharan 130 Carat TDI. Air con not working. regassed today and no leaks found but still not working. Then noticed the blower only works on 3 and 4. even when on, still no cool air coming out. There is also a noise when ignition is turned on just prior to starting engine, sounds like a stuck flap moving about in the dash.
    Any ideas if blower resistor will sort my air con and blower probs? I have been advised by an air con expert that the resister is at fault but I can't see how this will sort the air con, grateful for some other advice in here.
    Secondly, any ideas how to get to the resistor and possibly the fan as I fear this may be at fault too.
    Hope someone can help, on a seriously tight budget and can't afford garage prices
  6. Re: Heater Blower Motor / resistor
    Jan 2011
    bedford
    Well after such a kind offer, I truly hope you can help me!
    I have another thread on this but think this one is closer to my problem. I have a 2003 Sharan TDi. AC light wasn't working on blower settings 1 and 2. I replaced the blower motor resistor (actually I had it repaired) and now the blower works as it should on all 4 settings, and AC light comes on after a regas and confirmed no leaks in system. BUT .... the depressing news today..... my local mechanic had it in to have a second go at finding the problem. Firstly a diagnostics check found NO FAULTS at all on the car. He found no voltage was getting to the air con compressor so he then manually put voltage to it and this fired up the compressor but it made an awful noise and he said the compressor is definitely going to need replacing. If only that was all I would get a used replacement (short of cash) but he said that won't fix it because still that doesn't solve the problem preventing voltage getting to the compressor. He said it can't be just a broken wire because both ends of the feed to the compressor are showing earths so must be connected. He is at the extent of his expertise here and does not know what to suggest next other than an air con specialist with knowledge of this vehicle, a 2003 VW Sharan 1.9 TDI.
    CAN ANYONE HELP ME? PLEASE!
  7. Re: Heater Blower Motor / resistor
    #17
    Mar 2015
    redditch
    Hi All,
    I am looking at trying this fix on my 2011 A6 only difference being that my heater blower is located in the engine bay rather than behind the dash board, does anyone know if the part is the same or is it slightly different? also is there a picture anywhere showing the plugs that separate the motor from the housing?
    Many Thanks in advance
    Paul
  1. Question Heater Fan Blower problems
    By A4Ecosse in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2010, 11:02 PM
  2. How To Octavia Mk1 heater blower swap.
    By Pastedavid in forum Octavia
    Last Post: 17-02-2010, 05:08 PM
  3. Heater Blower Motor or something else?
    By Audi 80 Man in forum 80 - 90
    Last Post: 08-01-2008, 06:54 PM
  4. Heater core replacement 93 passat VR6
    By farmhemi in forum Passat - Archive Topics
    Last Post: 05-01-2008, 04:25 AM
  5. Heater blower problem
    By knight A4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-01-2008, 08:26 PM
