Thread: steering wheel controls
  1. Question steering wheel controls
    Oct 2010
    France
    Hello.
    First Sorry for mistakes I'm french.
    I have an audi a6 (chassis 4F) of 2005.
    A have a Vag-com wire and the programm VCDS (908).
    I have replaced my original steering wheel by a steering wheel with steering wheel controls.
    I also bought the wire to connect the new steering wheel to the car at AUDI.
    The problem is the fact that steering wheel controls doesn't work !
    So I opened VCDS and I went on 16-Steering Wheel Electronics:
    I change the original value 0 to 2:
    * 0xx?xxx: Steering Wheel
    o 0 = Standard Steering Wheel
    o 1 = Sport Steering Wheel
    o 2 = Multi-Function Steering Wheel
    but after that the command does not work !
    if anyone knows how to activate steering wheel controls?
    Ask me if you want photos or more.
    Thanks Thanks
  2. Re: steering wheel controls
    Norfolk
    Please post a scan from an up to date version of VCDS when asking for help
  3. Re: steering wheel controls
    May 2008
    Does VAGCOM accept or reject the new coding you're trying to enter?
    If your car didnt have Multifunction from the factory then you might need a new steering ECU (SCSM) that will support multifunction control.
  4. Re: steering wheel controls
    Ambler, PA, USA
    As I said in the MKIV forum, if you have a genuine lead, upgrade to the latest version and do as Martin has asked - post a full autoscan. If you are running a Chinese rip-off, then you may have a problem with the lead itself communicating in a proper way during coding of a module. I also posted a link to the Steering Coding for your 4F platform from the Ross-Tech Wiki.
  5. Re: steering wheel controls
    Oct 2010
    France
    Hello!
    Yes VAGCOM accept the new coding.
    But after acceptance Multifonctions still don't work
    Yes my car haven't Multifonction from the factory.
    <<If your car didnt have Multifunction from the factory then you might need a new steering ECU (SCSM) that will support multifunction control.>>
    The ECU of an audi a6 wich has multifonction and a audi which hasn't it are different?
    I'll post a scan soon
    Thanks.
  1. Heater Control Cable (air Distribution)
    By kwic50 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-09-2023, 03:11 PM
  2. How To DIS AND CRUISE RETRO FIT b6+b7
  3. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  4. Sloppy steering
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 04-06-2008, 02:49 PM
  5. mot
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2007, 06:20 PM
